AH FabricationsBadger5
    Synchromesh's Avatar
    Will Race For Cookies
    Jun 2009
    Belgium
    99
    000665 - Boost Pressure Regulation: Control Range Not Reached
    Hello,
    For a while now, my car has been holding back during accelaration. It seems to do this at random, it doesn't matter how fast I accelarate or what gear/rpm it's in. At some point, I noticed my dumpvalve started making a lot of noise, and the logs comfirmed it was knackered. I also had some huge cracks in my engine cover (you could clearly see the airfilter...), so with this in mind we started replacing a few parts:
    - new engine cover (bought a second hand S3 one from pinterovski)
    - rev d diverter valve (06H 145 710d)
    - TSB 28E9 (Coil pack recall)
    This helped a great deal, however my car still holds back sometimes (but a lot less worse than before). After checking the logs again, we found a new error:
    P0299 - 002 - Lower Limit Exceeded
    I searched the internet and unfortunately, there is no straight forward solution, just a lot of parts that could be broken.
    So my question is, with all the experience here, what would you guys check/replace first?
    Thanks in advance!
    PS. It's a 2006 2.0TFSI with 62k miles/100k km's
    Phantomschwarz Audi A3 2.0 TFSI quattro S-Line | Bilstein PSS B14 | Oem 8x18 ET43 5-Spoke | Facelift taillights | RNS-E MKII | My Thread
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    You need to check for boost leaks. Check all the boost pipes going from the turbo to the intercooler and then the intercooler to the engine.
    If you have vagcom then you could do with seeing what the wastegate duty cycle is running at, if its at 95% all the time during full throttle then you have a boost leak.
    Jun 2009
    Belgium
    99
    Thanks Robin, let's hope it gets sorted next week...
  1. 16683 Boost Pressure REgulation Control range not reached
    By Kev_M5KPL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2010, 20:22
  2. Boost Issue - Boost Pressure Regulation: Control Range Not Reached
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2010, 16:30
  3. Boost pressure regulation!
    By s_line_junkie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th May 2009, 19:04
  4. Replies: 4
    Last Post: 29th August 2008, 16:31
  5. Boost pressure control valve
    By imported_SYNAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2004, 09:33
