Techone ones will be £180
X5 ones will be £200
let me ask him about hella ones (hella doesn;t make "kits" but he can make up a hella kit using hella ballasts etc)
Free pnp
A few FAQ
Legal ? Yes
The MOT shouldn't be an issue with these bulbs providing they have been fitted correctly into their holders, the beam unit and reflector form the shape of the beam, not the bulb.
The is nothing about HID in the current MOT testing manaul, so therefore No reason for rejection.
As long as the beam pattern and aim is in spec and both lamps have equal intensity it's a good un.
factory fitted HID's which feature self leveling and wash are currently governed by construction and use regs, not MOT.
Will the conversion kit damage the plastic light cover (melting etcetc)?
No there are less heat than halogen lamps (35 vs 55) and bulbs have UV filter which is main issue
Diff between kits?
The X5 kit has waterproof ballasts and has a feel of a little bit better quality kit.
From a performance point of view there is nothing in it. If the ballasts will be located in engine bay then Techone is fine. If behind bumper or inner wing then i suggest X5
