    132
    Bump n' Grind [not the good kind]
    When I am driving I hear a metallic scraping noise from the back of the car, at first it was as if a steel girder (!!) was under my car, I pull over and check and nothing is there and the exhaust is fine not loose.
    Today I drive off and it happened again but I carried on, it got so loud I thought either the car would fall apart or the exhaust would drop off. Then I slow down, nothing, after going over a slight bump its back and went away after that.
    There is no loss of power or drivability, braking, etc. I am assuming someone has threw a few stones in the exhaust and they are deep in, but the noise doesn't act continious.
    My car has done this twice now over the last month and a half.
    A3 V6 DSG
    A3 3.2 S Line DSG
    A3 TDI S Line DSG Gone
    Update on A3/TT 3.2 V6 software update: See this post
    Aug 2009
    50
    I had a simular problem once before, it was a stone caught between the rear disc heat shield and the disc. Does it make the same noise in reverse? also going in reverse knocked the stone out ;-)
    Give it a go, hope this helps.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    as said above if its not a stone then it could even be the heat shield its self could have bent a bit and is catching the disk that makes a nasty noise to fix that literly push the heat shield away a bit from the disk its easy you don't have to push it a lot just a little bit , you can even do that with the wheel still on if you have got big gaps in your wheels to get your hand in there saves taking it off lol
    off the road boohoo anyone got a gearbox for me lol!!
    Farhan's Avatar
    Feb 2011
    West London
    1,228
    Had this sound to dude! randomly my cars a 1.8tfsi was going into car park all of a sudden hear this terrible noise as though the exhaust has fallen off and its scraping the floor. Look around the car nothing drive off and it happens again...Go over a bump it stop i was like huh...Never happened again.
    I to think it was maybe a stone or something caught in between brakes or a rotating part which caused it.
    2008 A3 1.8TFSI 3 Door S Line - Lava Grey - Bose - Bluetooth - S Line Full Black Leather - Aux - Comfort Pack - Coming Home Lights - Storage Pack - Cruise Control - Ambient Interior Light - Footwell Lights - Audi IPhone 4 Cradle - Leather Armrest - BE Rear - MY09 Rear Lights - S3 Pedals - S3 Vents - BBS RS866 - Bi Xenons - Bluefin Stage 1 - K&N 57S Intake - Rev D Valve - Powerflex Dogbone Insert & Gear Box Mount
    Sep 2011
    33
    Quote Originally Posted by Red-Eye View Post
    ^^ This. I had the exact same problem.. I was driving and bam scraping noise so I pulled over and everything was fine. Drove a bit and still there.. got worse. Pulled out and took wheel off and found a big stone stuck in rear disc heat shield
    TM
    TM's Avatar
    S-line SB
    Mar 2011
    144
    I've had the same thing previously also, like others have mentioned its most likely a stone stuck between the heat shield! Horrible sound!
    A3 Sportback 140 TDI S-line
    Mods: Number plate LEDs, Rear Rings delete, Rear S-line Badge, Internal Audi and Rings stickers, Silvatec chrome indicators, Interior LEDs, Chrome Fog Rings.
    Future mods: Remap, MY09 Rear LEDs.
    SOLD & SADLY MISSED
  1. Please help! 2nd gear grind.
    By justabloke77 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2011, 01:00
  2. Help Please!! Rub/Squeak/Grind from passenger front wheel/corner.
    By schwarmo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th June 2010, 23:02
  3. My brakes are vibrating, and it's not the good kind :(
    By boggysv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2009, 13:59
  4. Bump and Grind - What the hells that noise?
    By MikeSel^ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th May 2009, 10:04
  5. 2nd to 3rd gear change grind/crunch
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2003, 17:20
