Monster MotorsportEM Tuning
Page 1 of 2 12 LastLast
Results 1 to 40 of 46
Like Tree21Likes
Thread: A5 seats into an A3 ?!?
    munchkincoupe's Avatar
    Aug 2010
    971
    I'm looking at fitting a set of front seats from an A5 coupe into my 3 door 8P1. I've been told they will bolt straight in with no alterations but will the airbag be compatible? does it just need a plug change or will it not work at all?
    Thanks for quick replies
    Phatboyruss1 and Presns3 like this.
    warrenlord's Avatar
    Apr 2010
    778
    Yeah they fit.. You need to chop one of the locator lungs off from under bottom of the seat, and the air bag plug.
    That's it. Took me 20mins and I didn't even know if they was going to fit at the time
    Presns3 likes this.
    Aug 2010
    971
    So did you get the airbag to work then?
    warrenlord's Avatar
    Apr 2010
    778
    Quote Originally Posted by munchkincoupe View Post
    Well there's no warning lights... And it's not gone off so I would say yeah.
    Aug 2010
    971
    Did you just attach the correct corresponding plug for the A5 airbag to the wiring in the A3 then or have you spliced the wiring together?
    Did you need to get the airbag error code cleared too?
    Mar 2012
    Did you get the A5 seats in to you a3 ok?
    Feb 2008
    Europe
    231
    Like Warren said one locator lug needs chopping and then straight bolt on.
    For the airbag, I replaced the plug and service cables of the seat with a new one from the S3.
    Everything spot on.
    FYI, I fitted the rear seats from a S5 as well but that was a more complicated project. Needed a capable fitter
    who had to shorten the backrest of the S5 and fitted it on the frame of the S3. see photos.
    Mar 2012
    Excellent thanks ... I sort of understood that the front seats would bolt in but it's the electrics that concerned me .. Ive got the heated bucket seats and need to swap out "for access" and can't find the original s3 types so thought a retro s5 would be good ...
    Any idea if the you need more plugs/ looms for electric controlled seats or would are they standard ( I've got heated etc in mys3) or would I need to fit another loom
    Feb 2008
    Europe
    231
    Quote Originally Posted by Richie_h_uk View Post
    Under the S5 seat there is a electronics module that is connected to the MMI, that the S3 does not have. All seat cabling go through that module, therefore some work must be done to make all the connections correctly on the S3.
    On the top part of the backrest of S5 seat there is a switch for the easy entry, that should move the seat forward/backward, only with the door open. So you have to find the cables and connect to your door or courtesy light switch.The heated seat cables must be bypassed from the electronics module. I have yet to connect the heated seats. plug housing and service cables are needed. I had an Audi technician do the work for me. I can give you more info after we finish work.
    Presns3 likes this.
    Feb 2009
    Aberdeen
    2,600
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    PMd
    Presns3 likes this.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Mar 2012
    Klick thanks for the info - it sounds a bit of a mission but doable. I'm assuming the A5 s line seats will be the same.
    Would any Audi dealer or auto electrician do the electric work? Or is it a mate sorting as it were
    The forward tilt switch linked to the door, do the normal seats not also have this Or would it be worth getting an older model a5 seat??
    Sorry to be a pain and thanks for any help you can give
    Mar 2012
    Oh and any pics ???
    Feb 2008
    Europe
    231
    if you mean the regular S3 seat, no. In the case of the S5 (I asume the A5 is the same), everything goes through the electronics module under the seat. If you do not put people in the back that can play with that switch while you are driving, then you can supply a + and earth to the seat and all electrics including lumbar support will work. Connecting to your door switch is a safety feature.
    e.g. buy a plug cover from the S3's seat and service cables, fit them on the A5/S5 seat, then connect to the lumbar support of the car. All seat functions will work.
    Contact NHN, I am sure he is capable of doing the job. I doubt Audi will accept to do it.
    good luck
    Presns3 likes this.
    Mar 2012
    Excuse my ignorance.... NHN??
    So I guess I just need to take the plunge and buy them then sort the wires out ... I got a technical background so I should be able to figure it out..
    Any idea where I can get the wiring diagrams from?
    Thanks for all the help
    Feb 2009
    Aberdeen
    2,600
    NHN is a member on here, Nigel. He's a great guy, and will help you sort out just about any retro-fit issues, from seats to nav and more. If Audi make it, he can put it in you car. He can also supply just about any mods you fancy (from Audi).
    Presns3 likes this.
    Hunt is over
    Feb 2008
    Europe
    231
    I managed to get the 2 diagrams for the electrical connection of the seats for A3 and A5.
    hope this helps.
    Presns3 likes this.
    Mar 2012
    Excellent thanks
    Phatboyruss1's Avatar
    Apr 2010
    Button Moon
    65
    Follow Phatboyruss1 On Twitter Visit Phatboyruss1's Instagram Channel
    I really really fancy doing this mod to mine, silly question but do the electric seats have a lever to move them manually or do I have to find manual seats?
    I would like to have the airbags working though... side airbags pretty much saved my mates life...
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    it is unlikely but if youre up my way in scotland im sure we can come to some form of arrangement now i have gotten my garage clear with space for 2 cars
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    Ok so working on a friends car who has got himself A5 electric, heating and lumbar support... i have wired in the lumbar and electrics but the heating is really confusing me...
    so if i wire the heating seat pad directly into a fused connection it works, but if i connect it as per oem A3 diagrams on elsa then the seats dont warm up at all. I have also tested my wiring by disconnecting a wire and a fault appears on VCDS on the Auto HVAC control unit but as soon as i reconnect the wire and rescan the fault disappears. how on earth though do i get the seats to actually heat up?
    Has anyone actually managed to get heated seats working on A5 seats?
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Jul 2009
    24
    This is what I am trying to figure out with my audi s4 seats from a 2007. The heated seats are the only problem for me aswell. Does anyone have any experiance with these working with s4 seats in an a3?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,423
    and here i was today hunting A5 seats for my A4 cab
    stright fit looks like there will be in there soon
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    i will be looking into it deeper and see if i can rewire the heated seats around the control module on the A5 seats as the A3 does not know how to talk to it. if i had more time on my hands i may have even tried to see if i could make the A5 control module talk to the A3 and see if i can even get memory seats working :P
    this cold weather really does not help as its so hard to work on the cars later on in the day
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    Its one of my projects for next year once I put the seats into the trimmers gotta get engaged first though before I spend over a grand on trimming
    Mods
    Jul 2011
    106
    Re: A5 seats into an A3 ?!?
    Why not take the heating elements out of your stock seats and put them in the S5 seats?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    that would require the stock seats to have heating elements... the upgrade is being done to gain the heated seats
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
  28. #27
    Feb 2008
    Europe
    231
    Quote Originally Posted by OCD-A3 View Post
    Due to size difference it is not possible.
  29. #28
    Feb 2013
    Dublin
    16
    Ash there is a solution to your problem with heating. Has been done already and apparently works just fine.
    You need to connect lower part of the heating seat to climatronic panel, and upper part of seat by using relay to electric seat adjustment button. That way seat should heat up to maximum within 2min with no problem.
    It has something to do with Audi using voltage modules on the newer cars that reduce voltage from 14V to 12,5V once car engine starts.
    Presns3 likes this.
  30. #29
    AndyA3170
    I really want these seats in my car
  31. #30
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    Quote Originally Posted by KOZI View Post
    Talk to me!
    This has already been done and no errors from the car
    right so that way the upper part is connected to a constant power? wont that just make the upper pads warm up all the time? also is there a link to a thread where this is all described properly?
    thanks
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
  32. #31
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    im all ears on this just about have everything to goto the trimmers with mine
    Mods
  33. #32
    Feb 2013
    Dublin
    16
    Quote Originally Posted by Ash187 View Post
    Talk to me!
    thanks
    I wouldn't imagine that there is an issue with this type of connection since i guy for another forum that made this modification did not report any issues afterwards. Let me check that with him and i will get back to you guys ASAP.
  34. #33
    May 2012
    York
    241
    How do you do the rears?? I want these!!
  35. #34
    Feb 2013
    Dublin
    16
    So apparently the 'relay' he used is an answer to everything. The way I understand it is that on the wire that goes from bottom to upper part of the seat he fit in a relay that controls voltage and power that is used to heat up the upper part of a seat. That way if there is no signal from climate control to the seat about heating being turned on, the seat remains turned off. And whey signal is sent then a relay is doing its job. If that makes any sense.
    and another thing, just today I found out about different solution as well but i have only pictures of the device that was built to do the trick. I don't have any other details apart from that it has been made by some electrician to get heating working on 2013 sline seats from a3. Lovely seats tho.
    I can post pictures here if anyone is interested
    Presns3 likes this.
  36. #35
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    Great....Do you know what sort of relay he used ?
    If you can post pictures of the second solution that would great also.......
  37. #36
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Thought I'll give a little update guys.
    KOZI has given me some info I would like to share.
    Here are the pics of the other different solution.
    And Below is The New Audi S-line A3 8V seats in a 8p ...
    Just waiting for some more info ....I'll post when this is all solved.
    Dean_T and Presns3 like this.
  38. #37
    May 2012
    York
    241
    Wow they are very nice aswell!
  39. #38
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Quote Originally Posted by Bramley View Post
    Init ....I'm in love .... ..loool
  40. #39
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    look like snakes
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
  41. #40
    Aug 2013
    A5 convertible seats in an A4 convertible
    Hi just seen your message and wanted to put some a A5 convertible seats in my A4 convertible, do you manage to get yours to fit from your post above?
    thanks Steve
  1. Replies: 12
    Last Post: 11th March 2010, 18:22
  2. Gucci (i.e. Gorgeous, Sexy, Fabulous) S3 Seats(AKA S3 Bucket Seats)
    By martinivw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th October 2009, 14:05
  3. S4 or S-Line seats? Need door cards or tan leather seats?
    By sandspeed in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2008, 20:55
  4. A4 Seats
    By j10gtr in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2007, 12:49
  5. Bucket Seats v Standard Seats - Report
    By Spook in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2007, 16:02
