Sky InsuranceJMB Retrofits
Results 1 to 12 of 12
    Lewbo's Avatar
    Aug 2009
    Hull
    1,061
    2.0T cam follower replacement and look how bad this is!!
    Hi
    I have a 2.0T and had it for a year now great engine, but was looking at common faults the other day as my DV went few weeks ago and I changed my PCV valve too and read that the cam follower was very common problem and symptoms are fuel cuts, well sometime when my dsg gearbox changes gear it felt like a slight jerk like no fuel was there so anyways thought I would change the cam follower.
    Picked it up today from Audi and fitted it tonight only to find it like this: I have compared it with the new one
    So fitted the new one and it felt so much smoother when I changed into 3rd gear ect this was the worst gear before.
    What I wanted to know is would this of caused any damage to my engine at all I have looked at the cams through the hole and seemed fine to me, No damage it anything. Would this of made my car slower also with the old follower
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    Lewis583's Avatar
    Mar 2010
    872
    Bloody hell, that's well knack'd mate. No scoring or grooves in the cam at all? If not then it seems you are very lucky.
    It would have had a slight affect on fuel pump plunger lift/pressure, but not enough to impact performance i would have thought.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Lewbo's Avatar
    Aug 2009
    Hull
    1,061
    I know I was gutted when I saw it, there where very tiny light marks on the cam nothing deep or anything like that, don't know how long it's been like that though, was very lucky that I just randomly decided to change it.
    Thought it was strange when I went to bleed the valve of the HPFP and there was nothing there would this mean anything :s?
    Current
    previous
    Lewis583's Avatar
    Mar 2010
    872
    Did you have the igntion on or drivers door open when you tried to bleed it?
    How much did the plunger cost you? I intend to strip mine at some point to check the condition.
    Full VCDS
    Lewbo's Avatar
    Aug 2009
    Hull
    1,061
    No it disconnected the battery and door was closed, the cam
    Follower was £24 all in with vat well wort buying and changing even before you look at yours piece of mind to be honest mate
    Current
    previous
    Mar 2011
    85
    Can't believe the state of that! How many miles has it covered?
    Lewbo's Avatar
    Aug 2009
    Hull
    1,061
    I know mate and has covered 33k so don't reckon it's ever been changed.
    Current
    previous
    warren_S5's Avatar
    Oct 2007
    7,166
    That's unbelievable considering your mileage.
    1) do you rev it hard from cold
    2) are you on fixed or variable long life serving
    3) do you drive the car hard
    I didn't manage anywhere close to that with HPFP & S2+ and similar mileage
    Audi S5 3.0V6T Coupe Black Edition
    Silky-S3's Avatar
    Is loving his new 8V S3!
    Jan 2009
    1,390
    33k!!!! Thats crazy! I changed mine a few days ago and it did not even have mark on it.
    S3 8V Sportback Stronic, Estoril Blue Crystal Effect, Black Interior, Adaptive Cruise with Stop & Go & Pre Sense, Super Sports Seats with Electric Lumber, LED Headlights, Interior Lighting Pack, Hill Hold Assist, Privacy Glass, Comfort Package, Technology Package with Audi Connect, Advance Key, Folding Door Mirrors, Extended Mono.Pur Interior, Front and Rear Parking Sensors, Audi Sound System.
    Build Thread Here!
    Mar 2009
    120
    I'm 99% sure that you have to change intake camshaft and HPFP. I've had the same problem and put a new cam follower. After 30km (~20miles) the black protective coating had scratches on it! Need new cam follower or new HPFP? - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com replaced camshaft with S3 ones and new HPFP!
    Cheese's Avatar
    Mar 2011
    Surrey
    180
    Quote Originally Posted by a3_sline_tdi View Post
    HPFP
    AmD recommend checking it every 5,000 miles if you have a HPFP. I think APR released a TB about it as well. You were lucky it wasn't worse - could have needed a new engine - I saw the aftermath of a similar problem on an S3 when I was in getting my car remapped.
    Audi S3 8P3 | Milltek TBE | AmD Stage2 | H&R ARBs | Bilstein B14 Coilovers | Sachs Racing Clutch
    Oct 2011
    Stockholm/Sweden
    34
    Hope all the metal missing is in the bottom magnetic plug ...
  1. KMD Uprated Cam Follower - Stage 2+
    By Kelza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th July 2011, 15:16
  2. KMD Uprated Cam Follower - Stage 2+ Users Please Read!
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th April 2010, 18:06
  3. TFSI Fuel pump cam follower
    By KRL in forum Parts Requests
    Last Post: 2nd February 2010, 14:43
  4. Cam follower inspection per Audidriver recommendation-2.0T
    By master mariner in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th March 2009, 10:49
  5. 2.0 TFSI HPFP Cam Lobe and Cam Follower
    By KRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2008, 05:46
