Results 1 to 20 of 20
    Feb 2011
    535
    Can anyone get cheaper Eibach springs than these?
    Eibach Sportline Lowering Spring Kit for Audi - larkspeed.com
    After a quick look around, this is the cheapest I've found. Does anyone know of anywhere cheaper?
    WANTED: S3 Side Skirts (3DR)
    A3 S Line DSG TDi 140 (56) | Lava Grey | Groove & Drilled Discs | Green Stuff Pads | Eibach Sportline Springs | Eibach Spacers | Full heated leather | RNS-E 2010 MK2 | Rear Parking Sensors | Interior Light Pack | Heated Mirrors
    1inchpunch's Avatar
    Apr 2011
    Glasgow
    449
    I ordered from them last week. Delivery is £10 but I still couldn't find anywhere that did them cheaper delivered.
    I ordered mine at lunch time on Wednesday and they were with me by lunchtime the next day. Packing label says they came direct from Eibach. Amazing service, can't fault them.
    the crisis mobile BMW Z4C 3.0
    It's quick and it sounds bloody good.
    Feb 2011
    535
    Quote Originally Posted by 1inchpunch View Post
    That's me sold. Thanks
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Yep, good price that is.
    I think the cheapest I've seen elsewhere is about £160.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    I bought my full kit from there.
    cheapest than any where else.
    Good service, recommended.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Your other option is:
    If you are going to pay to have them fitted and you live anywhere near an AMD then they will supply the springs and front top mounts, fit and align it all for £299 all in.
    Feb 2011
    535
    Quote Originally Posted by Ads View Post
    What are the top mounts for? and are they a must when fitting new springs? I've not heard of this before.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by Agent_Trig View Post
    It really depends on the state/mileage on your current ones. They sit at the top of your struts connecting to the car.
    If yours are worn you don't want to put new springs in and then have them starting to knock etc because of the extra stress on them, and then having to pay labour again to have them fitted a few weeks/months later.
    Most prefer to get them done at the same time as lowering because while the suspension is being taken apart its easier/more cost effective to have them done at the same time.
    Feb 2011
    535
    I see, makes sense. Do I just need to replace them with OEM or uprated ones? What kind of cost am I looking at just for the parts?
    1inchpunch's Avatar
    Apr 2011
    Glasgow
    449
    I got them from here SKF Audi | Euro Car Parts UK’s No.1 Car Parts Retailer When I bought them they had 25%off so were a fair bit cheaper.
    I decided it was just as well replacing these at the time of fitting the springs for all the reasons Ads mentioned.
    Aug 2003
    292
    As I'm about to get the Koni FSD and probably the Eibach Pro 30mm spings should I change the Top mounts? 07 2.0Tdi 170 dsg sportback with 37k miles.
    The reason why I even started thinking about the suspension is the knocking sound when going over speedbumps, potholes that an Audi mechanic said was likely to be a shock after a test drive. I had all the suspension inspected prior to to that at Kwik fit and they said all looked ok but can a top mount problem be ruled out?
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    I wouldn't take what kwik fit said as gospel. Knocking nosies over bumps etc could be down to many things... top mounts included.
    Sometimes it doesn't even have to be suspension related. I had a knocking on my last A3 and it was the engine mounts.
    Aug 2003
    292
    Cheers,
    it's comoing from the rear axle as there is no sounds when the front axle goes over the bump or pothole.
    is there a suspension mounting kit that one should use when replacing shocks? as you said beofre it's labour efficient to get it all done at once.
    1inchpunch's Avatar
    Apr 2011
    Glasgow
    449
    I'd be surprised if anything in your suspension is knackered after 37K.
    I had a creaking noise from the rear of my last car. I was obsessed with it and was convinced that a wheel would someday just fall off. I put the car into my friends garage and he spent 3 days searching for the creak. He said it was like that old VW advert where the woman turns out to have a squeaky earing (anyone else old enough to remember that ad?). In the end it turned out to be a lower suspension bush that wasn't worn, it just creaked.
    I'd change the mounts just so you can eliminate them.
    Aug 2003
    292
    Sorry ignore last post as I just link in this post and the mounts for the rear suspension come in at £54
    Donny_DJ's Avatar
    Oct 2010
    Surrey
    119
    Ha ha, classic!
    Audi A3 2.0T FSI S-Line Special Edition, 2006, Avus Silver. Eibach Pro springs, H&R 10+12mm Spacers, AMD remap, MY11 Rear clusters, Flat bottom steering wheel, Chrome S3 SE Gearknob, R8 Oil Cap.
    I mix house music: http://soundcloud.com/donny_dj
    Instagram (cars n stuff): http://instagram.com/donny_dj
    Aug 2003
    292
    I do remember that ad, a Mk2 Golf Gti I think.
    The reason the Audi mechanic said he thought it was a shock was that it was double sound clunk when you go over a bump like something knocking on the way up and then the way down
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    how much difference will these springs make.drop to the sline suspension?
    Aug 2011
    56
    I'm quite interested also in lowering my car, has anyone got a pic at all with these springs?
    Oct 2011
    Stockholm/Sweden
    34
    Hi I have a S3 SB anyone tried just swapping the front springs to something that lowers around 35mm, 10mm more than stock?
    Just to get the same gap as the back...
    /M
  1. Eibach ARB's & Eibach Springs for S3 (8L)
    By MikeA3 in forum DPM Performance
    Last Post: 17th September 2009, 09:11
  2. eibach springs help
    By d18ony in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2009, 22:59
  3. Eibach springs
    By starski4578 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2005, 00:45
  4. Eibach springs
    By FezzR in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd September 2005, 21:48
  5. H&R Sport Springs vs. Eibach Prokit Springs
    By Kasper in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th May 2004, 09:17
