    May 2011
    24
    Coolant level dropped then stopped
    When I checked my coolant level last week I noticed it was one or two mm below its usual level . Just checked again and it has fallen no further over the last week . Anyone have any idea why this would happen for the first time in 9000 miles since its last service . Could it be the colder weather ?
    Sportback owner
    Apr 2007
    France
    496
    Lincoln, you have probably been using the heater a lot recently as we get into the winter weather. This would mean that coolant is now often circulating through the heater matrix. A slight leak in the heater matrix or connecting pipes would perhaps explain it. Suggest you run around with the heater off for a week, and then check the level. Repeat with the heater on full and see if there is a difference. Do make sure that the car is sitting on level ground when checking the coolant level. I have noticed that even a slight slope gives a mm of difference. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    27,114
    Think you need to stop worrying mate, mm's arent the time to worry, its when it becomes cm's/inches you need to get the air raid sirens out, just keep an eye on it weekly, if it continues to drop at a rate then check it out.
  1. Coolant level once again
    By Matt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2010, 18:25
  2. Coolant level ?
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2008, 11:42
  3. Coolant level on S3
    By JESSER S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2008, 16:54
  4. Coolant level
    By Clach in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2007, 09:46
  5. HELP PLEASE - Coolant Level??????
    By cdb2 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th October 2006, 12:50
