JMB RetrofitsChris Nott
Results 1 to 36 of 36
Like Tree2Likes
  • 1 Post By paultaylor
  • 1 Post By miw615
Thread: Softening A3 Sportback S Line suspension
    Aug 2003
    292
    I know it might sound unusual but on my wife's 07 A3 2.0TDI 170 DSG S Line I've found the suspension too hard when going over Irish potholes.
    Hence I was looking for a damper/spring change that might maintain the lowered ride yet provide a softer set up over the bumps and poor roads.
    The Bilstein B12 coilover set up was suggested but as that will drop the car by a further 5-10mm I was wondering is there a different damper that I could get to work with the existing springs or would both have to changed?
    As one of the rear shocks is making a noise when going over bumps/speed bump they both have to be replaced so rather than replace them with the same I thought it'd be a good time to make a change.
    Any suggestions?
    I'm prepared to allow the body roll to increase as the car is more of motorway cruiser rather than a three wheeling R32 style car!
    thanks
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Eibach Pro springs (30mm) matched with Koni FSD shocks.
    You'll probably drop 5mm on s-line height but the ride and comfort will be greatly improved.
    Oct 2003
    up north...
    767
    i agree eibach pro -30mm and koni FSD - a fantastic combination for the A3
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    Aug 2003
    292
    cheers,
    any tips on where to get this combo and advise labour hours to fit?
    Aug 2011
    277
    Quote Originally Posted by Ads View Post
    I like this solution ( better than changing to 16" wheels) but how and why does it work?
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Where are you based?? If anywhere near Essex/London then AMD Essex will supply, fit and laser align for a very good price.
    Fitting will take a few hours (3 or 4hrs probably)
    Otherwise, DPM performance are very competitive with their supply-only prices. Damian is always helpful so drop him a PM ---> View Profile: DPM - Audi-Sport.net
    Look up the springs/dampers here for your model for an idea of prices:
    DPM - Audi A3 8P Lowering Springs
    DPM - Audi A3 8P Dampers
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by WAFTER View Post
    Sorry, how and why does what work??
    vorney's Avatar
    May 2011
    leeds
    121
    Quote Originally Posted by paultaylor View Post
    Any suggestions?
    thanks
    fancey selling your shocks and springs let me no
    Aug 2003
    292
    Quote Originally Posted by vorney View Post
    I'll send you a PM
    Aug 2003
    292
    Thanks for the info, I'm in Dublin so DPM could be just the job.
    Would you reckon the Eibach and Koni FSD would be softer the an the Bilstein B12 coilovers?
    I'm looking for the most comfortable ride possible while maintaining the s line ride hide as much as possible.
    Oct 2011
    57
    Check out some coilovers, for example, V-maxx adjustable coilovers, iv put them on my s3, dropped it, and the ride is still great, obviously you dont have to drop it.
    Aug 2003
    292
    Quote Originally Posted by ps44u View Post
    Thanks for that, I had a look and they seem well priced at £414
    Would anyone know how the s line 25mm drop springs compare to the Eibach springs?
    Would the fact that they are 5mm lower make them harder?
    Paul
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    I've never been in a Bilstein coilover'd car but the general rule is that coilovers offer a firmer ride than spring/damper kits.
    Paul
    I've got the lower Eibach Sportline (50mm) springs which will be firmer than the Eibach Pro (30mm) springs.
    At ADI recently me and Farhan (who has an s-line on standard s-line suspension) drove our cars over grass and tarmac to compare the ride quality. His s-line was definitely firmer and less forgiving over bumpy ground, whereas mine was quite good over the same terrain, and the Eibach Pro / Koni FSD combo will be even better than mine.
    Eibach springs are specifically designed to be soft over smaller bumps and firmer when needed.. i.e. under hard braking, fast cornering, etc.
    Google eibach pro and koni FSD and you will find loads of reviews about the set up.
    Aug 2003
    292
    Thanks for the advice, leaning towards Koni FSD and Eibach Pro 30mm
    and having read the thread on your conversion I'm really beginning to like the fat fives!
    I have the Factory speedline 18 multispokes but I think they look too old fashioned(was looking for 18 RS6 style rims like the ones you had a first but everyone tells me I'm mad to change) so thinking if I could find some OEM fat fives they might look the business.
    Tyre wise would 245/35/18 give a similar sidewall to the current 225/40/18?
    cheers
    Oct 2003
    up north...
    767
    theres no advantage to going to 245/35/18 over 225, and if you get et45 or lesss offset wheels then 245 tyres may catch at the rear.
    the 225 width is more than enough, there are lots of choice and they are cheaper - its a win-win
    if you change wheels then an et45 will fill the arches nicely at 225 width without any risks of catching, even if you have lowered
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    Aug 2003
    292
    Quote Originally Posted by dunk View Post
    Thanks,
    Does a 225 tyre not look very stretched on the 8.5J rim? Also is there an increased risk of pressure on the bead?
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Thanks,
    Nah, here are mine, i'm running 225 tyres. Its only a slight stretch.
    Aug 2003
    292
    those wheels with the colour of your car looks savage
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Cheers man.
    The surface area of the spokes are pretty large so they attract loads of dust and dirt. They look nice and shiny for about two days and then they're quickly back to not so shiny.
    Aug 2003
    292
    a hell of lot easier to clean than the mulitposkes on my A3! not to mention the multi spokes I had on my 07 R32.
    Your wheels remind me of the OEM 17s that I had on my 95 XJR, big open space that end up looking bigger than they are.
    Aug 2011
    277
    Sorry didn't make myself clear. Wanting a softer ride on my 'S' cab. have been told smaller wheels and deeper profile tyres would do the trick, so mystified how changing springs and shocks will do the same - then read subsequent posts....! It seems different springs and shocks are softer. Is that correct?
    Oct 2003
    up north...
    767
    yes - but also better shock design that copes with smaller bumps much better
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    Oct 2012
    I have an Audi A1 136 KW S line and it' s really hard in wavy roads, should I only get Koni FSD schock absorbers? I want a comfortable and soft ride.
    Jul 2012
    Essex
    183
    Fit 16 or 17 inch wheels, easy, job sorted.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Quote Originally Posted by Audil View Post
    Try changing to the Eibach Springs, the shocks are fine, its the standard springs which are badly matched to them. The Eibachs are 'progressive' so they'll be comfortable for normal driving but will react better when pushing harder.
    Quote Originally Posted by Soot1 View Post
    Yeah, if you want your car to handle like a boat. Higher profile tyres with a heavy but 'sporty' engine engine aren't a good combination.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Oct 2012
    Which model do you recommend for eibach springs for Audi A1? The original springs will not be good?
  28. #27
    Jul 2012
    Essex
    183
    Quote Originally Posted by max69vk View Post
    It really is a minor difference in the handling dept. but a big gain in comfort. The OP did say he's more akin to motorway cruising.
    I do agree that the Eibach springs are better than the OE springs, I've had them on previous cars, they are very supple in absorbing potholes in the road, yet do a decent level support in the twisty bits. In fact I would use them with new OE dampers, this was the concept of the Eibach springs and what they were designed for and where they score best.
  29. #28
    Aug 2003
    292
    I got my Eibach springs last week so I might go ahead and just fit them rather than waiting for Koni FSD dampers.
    miw615 likes this.
  30. #29
    Oct 2012
    Which model of eibach springs did you install?
  31. #30
    Oct 2012
    Are you happy with the eibach springs? Is it more comfortable now?
  32. #31
    Oct 2012
    Just resurrecting this thread. What's the general consensus these days for softening an A3 8P S-Line suspension? Is it still as above? Would love to hear of anyone's experience where they changed it.
  33. #32
    May 2012
    York
    241
    are knoi fsd shocks any good for handling etc or are they just designed for comfort and not really an upgrade??
  34. #33
    miw615's Avatar
    Feb 2013
    Surrey
    446
    Ver interesting thread - I have the same problem concerning the hard ride and too am considering Eibach springs only , keeping the original shocks.
    Have you fitted the springs, where did you get them from and how much did you pay?
    Has is made the difference in ride quality that you wanted
    Malcolm
    Malcolm
    Audi A3 2.0 TDI S-Line Sportback
  35. #34
    Aug 2011
    277
    16" makes the ride bearable and the fact that it might be less 'cool' looking is of no consequence. My understanding is that the new A3 S-Line has non-sport suspension as standard. My experience is that main dealers don't like p/ex cars that have been 'messed' with, so come the time to order new cabriolet will simply replace wheels with OE 18".
  36. #35
    Oct 2012
    Do the A3 8P's 18" 20-Spoke alloy wheels fit with the above recommendations on springs?
  37. #36
    miw615's Avatar
    Feb 2013
    Surrey
    446
    I would just like a softer ride WITHOUT altering the ride height so is there an Eibach Pro spring that will give me what I want?
    T33_BKD likes this.
    Malcolm
  1. just got 07 A3 Sportback 2.0 TDi S line, advice on suspension knocking needed.
    By paultaylor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th October 2011, 21:23
  2. Fitting an S-Line diffuser on ´06 Sportback with S-Line exterior?
    By Tracebuzta in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th July 2011, 21:58
  3. Replies: 25
    Last Post: 17th February 2011, 13:45
  4. S-Line rear bumper on non S-Line 2006 Sportback?
    By cooltempo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th May 2010, 17:13
  5. Replies: 0
    Last Post: 10th January 2010, 15:05
