Monster MotorsportEM Tuning
    Oct 2011
    Newcastle Upon Tyne
    57
    Fitting Parrot, removing RNS-E
    Guys,
    About to give this a go tonight, i've bought the connectors although ive been told i might not need them?
    Fitting a parrot C3100 to a RNS-E what do people think?
    Also ive bought the tools to pull the headunit, but whats the technique to getting it out??
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    The standard Parrot connectors are ISO's, the RNS-E uses a Quad-lock connector to you will need the harness to connect the two together.
    Push the keys into the slots until you hear a slight click then slightly push the keys away from the radio as this will release the tab easier and gently pull.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    plezz's Avatar
    Aug 2011
    Romford
    233
    i dont know if its the same for RNSe as it was for my chorus/concert/crap thing, but i had to push all 4 keys in like JB0o says above, but i i found if you pull the left keys slightly to the left, and the right keys slightly to the right at the same time as pulling the whole thing out of its hole that helped. obviously dont put too much sideways force on in case you bend the keys and jam them in there, but i found that worked.
    i cant be certain your removal process will be the same as mine though! plus there are tons of videos on youtube.com showing you how to do it.
    Apr 2009
    Florida (previously Liverpool)
    655
    You'll need quadlock.
    The RNS-E is a TIGHT fit in there... as well as the keys, you might want to try pulling -GENTLY- on the inside edges of the recess where the screen frame (which will be lying in the open position, I assume... that's how I do it!) to get some more pulling 'grip'.
    I had a Parrott, -eventually replaced it with the OEM phone module. -Some stuff was nice on the Parrott, but on the whole I like the Audi module better, specially in terms of DIS integration.
    If you don't have quadlock connectors, don't start the job... you won't make ISO's fit.
  1. Fitting PARROT MKi9200 to RNS System - anyone done this?
    By Moby Dick in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th October 2011, 17:36
  2. Fitting Parrot Mki9200 Help!
    By boulto232 in forum In-Car Entertainment
    Last Post: 27th November 2009, 13:28
  3. Fitting a Parrot
    By morgan306 in forum In-Car Entertainment
    Last Post: 7th November 2009, 19:34
  4. Fitting a parrot
    By auroan in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th January 2008, 17:34
  5. Fitting Parrot CK3000 Evolution Kit with Parrot Multiscan
    By Marcyboy in forum In-Car Entertainment
    Last Post: 16th January 2008, 17:23
