Sky InsuranceVolks Autos
    Jan 2011
    119
    a3 2.0 tdi 2004 8p shudder on idle when warm, timing???
    Hi guys, ive had this problem for ages now and i have recently purchased vag-com i eonderd can somebody tell me how i can tell if my timing is out using vag com? something to do with the cam timing? I have had a shudder, idle vibration since i bought the car a year ago and ive done 9000 miles in it since. Also how do i up my idle speed with vag-com? Do you think the vibration could be the result of timing? Also it had a timing belt kit fitted 15000 miles ago, however thats all it had, a water pump was never fitted at that time! For me its common sence to replace the water pump aswell. Do you think this is an issue? Should i replace the whole kit again, i.e. water pump timing belt kit etc. Also is this a job i could do myself? How much would this cost? Would be great if someone knows what my problem could be with the rough idle and vibration.
    Chris
    May 2010
    London
    334
    It could be the throttle body, its common for it to go faulty, had a similar thing with my car. Mine didn't through up any faults for a while then the engine light came on so though it was time to replace it.
    tdi-man's Avatar
    Jul 2009
    1,587
    only the front cam can be checked in vag com the rear cam has to be manualy checked which is 99% shacking on idle fault
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    tdi-man's Avatar
    Jul 2009
    1,587
    throttle body wont cause bad idle unless theres an air leak it ONLY stops the shudder when switching engine of
    Fossie
    Rhubarb Triangle
    3,961
    This is how to up the idle speed with VCDS :-
    how to turn tick over up
  1. A3 2.0 tdi, eratic idle sounds choppy once warm
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2011, 08:27
  2. Bad idle when warm 8P A3 2.0 TDI
    By Rigla in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th June 2011, 10:49
  3. B6 TDI 130 lumpy idle when warm problem
    By ian-r in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2011, 23:45
  4. Wobble/ Vibration on warm idle diagnosed by Midland VW
    Last Post: 2nd February 2011, 12:21
  5. Vibration at idle when engine is warm.
    By PhatBob in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th September 2009, 10:43
