Monster MotorsportEM Tuning
    Feb 2011
    534
    Another failed attempt :-(
    I tried a while back to remove the lower console triangle handles to replace with new ones as they are looking a little worn. After removing the ashtray and the gear surround, I then found out that one of the nuts is located right at the back underneath the air-con unit and none of my sockets would fit.
    Since then I found out on here I need an 8mm socket which I bought yesterday but I just cant seem to get the nut undone. Because of where it is, I'm finding it impossible to get any leverage to undo the nut.
    Any tips?
    I think that if I removed the air-con unit, that could help but not sure how to remove this either.
    WANTED: S3 Side Skirts (3DR)
    A3 S Line DSG TDi 140 (56) | Lava Grey | Groove & Drilled Discs | Green Stuff Pads | Eibach Sportline Springs | Eibach Spacers | Full heated leather | RNS-E 2010 MK2 | Rear Parking Sensors | Interior Light Pack | Heated Mirrors
    BBlackburn's Avatar
    Jul 2011
    Epsom, surrey
    395
    The triangles either side of the gear stick have a Allen key slot underneath look right under you'll see it and also the 8mm nuts search for double din conversion either here or on google to get all the relevant 8mm bolts then use the Allen key.
    Hope this helps.
    SPEC: ebony pearl black ~ auto lights ~ auto wipers ~ half leather/suede interior ~ armrest ~ anti dazzle rear mirrior ~ coming home/ leaving home function.
    MODS: flat bottom steering wheel ~ bluetooth ~ cruise control ~ rns-e ~ MY09 rear lights ~ s3 pedals ~ s3 air vents ~ LED interior light pack ~ facelift buttons ~ dension ~ SDS ~ Aliminium inlays ~ full grille conversion.
    FUTURE MODS: lower ~ black edition rear ~ s-line/facelift front ~ black headlining ~ BBS CH-R or Speedlines.
    Farhan's Avatar
    Feb 2011
    West London
    1,228
    the air con unit can be removed to help, Get a screw driver with a bit of tape wrapped around the end or a bit of cloth to undo the trim around the card holder assuming this is a double din.
    When the trim around the trim around the card holder is popped out, You need to get your fingers on the air con panel from the top push down a bit to release and pull it out. Undo connectors and its out easy enough.
    Hope that helps
    2008 A3 1.8TFSI 3 Door S Line - Lava Grey - Bose - Bluetooth - S Line Full Black Leather - Aux - Comfort Pack - Coming Home Lights - Storage Pack - Cruise Control - Ambient Interior Light - Footwell Lights - Audi IPhone 4 Cradle - Leather Armrest - BE Rear - MY09 Rear Lights - S3 Pedals - S3 Vents - BBS RS866 - Bi Xenons - Bluefin Stage 1 - K&N 57S Intake - Rev D Valve - Powerflex Dogbone Insert & Gear Box Mount
    Feb 2011
    534
    Superb, I'll try this.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    get a socket extension bar?
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Feb 2011
    534
    Quote Originally Posted by itwasntme187 View Post
    Most will need one of these. I'll see what it's like once the air-con unit is removed.
  1. My first attempt at light trails.
    By Mick a3 in forum Photography & The Digital Darkroom
    Last Post: 26th October 2009, 08:58
  2. First attempt at detailing
    By col6821 in forum Detailing
    Last Post: 9th January 2008, 10:02
  3. First attempt on my A3
    By Craigybaby37_A3quattro in forum Detailing
    Last Post: 4th January 2008, 20:40
  4. S3 Donought attempt
    By nky_84 in forum You Tube Links
    Last Post: 25th May 2007, 13:38
  5. I shall now attempt...
    By audi5e in forum Classic Audi Forum
    Last Post: 27th February 2006, 19:00
