Volks AutosAH Fabrications
    Mar 2011
    25
    Not firing after I play my aftermarket sub
    Have a 05 a3 tdi sport, it seems to not start perfectly after I've been playing my music , it works the first time I've started the car in the morning any ideas ?
    Fossie
    Rhubarb Triangle
    3,961
    Probably nothing to do with the music.
    Hot starting problems are common on the BKD engine and at that age the most likely cause is a failing starter motor.
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    Could be Sub related actually. What sub /amp are you running OP? If the amp and sub are drawing a lot of current it could be draining the battery, making it harder to start if you turn it off and re-start just after blasting your tunes. However this is only if your running a serious set up like 2500 Watt RMS atleast. Do the lights flicker with the basslines?
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    marknjayne's Avatar
    Sep 2011
    worksop
    423
    get yourself a power cap something like this
    xanderxxx's Avatar
    Jul 2011
    Brizzol
    86
    maybe the car is protesting about your choice of music
  1. Cylinder 2 not firing
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2010, 18:59
  2. Mis-firing on Start up till warm..
    By V.I.P_UAE in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2009, 23:20
  3. Replies: 4
    Last Post: 17th November 2008, 13:40
  4. Help.....Lost Power / Firing on 3 cylinders........ ?
    By hop2407 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th March 2006, 22:12
  5. Windscreen Washers not firing?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 08:50
