EM TuningVolks Autos
Results 1 to 16 of 16
    sturs4's Avatar
    Aug 2010
    186
    Wheel Spacer problems
    Im running 20mm spacers on my S3.Nearly one thread on each spacer has stripped just torquing the bolts up.Has anyone else had a similar problem?
    Ive just given my self the fear of going round a corner and my wheel departing from the car,plus its on the rollers on saturday and i want it to be sound before hand.Im going to replace them but if this problem is a regular occurrence i'm not going to bother.
    cheers
    Lund's Avatar
    Sep 2011
    146
    They sound cheap and nasty to me despite how much you may have paid. Find a supplier who will supply you with a set of stainless reinforced jobbies.
    sturs4's Avatar
    Aug 2010
    186
    Lund's Avatar
    Sep 2011
    146
    Quote Originally Posted by sturs4 View Post
    I wouldn't be able to compare I'm afraid. The advert doesn't address the quality/grade of the threads. However I wouldn't recommend 20mm spacers in any circumstance!
    sturs4's Avatar
    Aug 2010
    186
    Quote Originally Posted by Lund View Post
    Sadly i need them for my Maybachs to fit.
    Lund's Avatar
    Sep 2011
    146
    As you say you're probably better off with the Eibach's then as they're hubcentric and shouldn't cause too many adverse problems.
    crunchie's Avatar
    Oct 2009
    Inverness
    861
    Surely 20 mm spacer will eat wheel bearings!
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    1inchpunch's Avatar
    Apr 2011
    Glasgow
    449
    If your wheels need 20mm spacers to fit then I would suggest the spacers aren't the problem. Get some wheels that fit properly.
    the crisis mobile BMW Z4C 3.0
    It's quick and it sounds bloody good.
    c_w
    1,050
    If the spacers are the sandwich type that are clamped between the wheel and the hub, surely it is the wheelbolts that are the issue? I take it you have the correct length longer bolts?
    sturs4's Avatar
    Aug 2010
    186
    They are the type that bolt to the hub then the wheel bolts to the spacer.Having them on isnt gonna be an issue as its bringing the ET of the alloy to standard fitment.Its a case of **** quality spacers i think.You can make anything fit properly,its just finding the right quality parts to do so,thats why im asking.
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,788
    Pm N8 im sure he will be able to tell you what spacers to use and not use.
    Dark Vader Half sibling - MyThread
    Rob-Quattro's Avatar
    Sep 2011
    Cambridge
    207
    Quote Originally Posted by 1inchpunch View Post
    What kind of post is that???
    Lava Grey A3 Hatchback S-line 170 Quattro, 18" Speedline Turini's, Bilstein B8 Shocks, 35mm H&R Springs, H&R ARB's, Small Remap, Darkside Development EGR Delete, K&N Panel, Full S3 Brakes, Yellow Stuff Pads, Drilled/Grooved Disc's, Bi-Xenons, DRL's, Full Leather, RNS-E/Changer/Bose, LED Interior Light Pack + Ambient Lighting, Rain And Light Pack, Rear Parking Sensors, Cruise Control, Auto Folding Mirrors, Black Grill/Badges, MY11 Rears, Lamin-x Fogs.
    1inchpunch's Avatar
    Apr 2011
    Glasgow
    449
    Consider it a public health information post I don't really want to see the OP die when his wheel falls off. The spacers he has are clearly made of toffee or something.
    I have nothing against spacers but please use good ones. If you really want to fit those wheels then get H&R or Eibach spacers or anything else that is TUV approved and hubcentric rather than the kind you have. It will require longer bolts as well so will work out more expensive but will be safer.
    c_w
    1,050
    For those kind of spacers I would use H&R, I had some of those on another car and they seemed top quality. I didn't think the cheapo makes bothered making those kind though! I think I bought them from Performance Car Parts / EBC Brakes / Eibach Lowering Springs / Koni Suspension Kits / Magnex Exhausts / Powertec Induction Kits - Euro Performance or something like that. These kits come with the bolts as they are specific to the spacer so seem better value than the traditional sandwiched spacer.
    sturs4's Avatar
    Aug 2010
    186
    Ive gone for hubcentric spacers with longer bolts.ive been told this is the best way of doing it on something like a S3 because the wheels are going to be bolted straight to the hub and not the spacer making it much stronger.
    brough74's Avatar
    Oct 2010
    423
    One of my longers bolts did the same when i changed tyres over, luckily i had a spare due to fitting longer locking bolts. I swapped it over and its fine. Basically if all of them torque up ok then you will have no issues
    S3 gone but not forgotten, now on a Golf R
  1. Wheel Spacer Suggestions Please
    By CHRIS555 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th January 2011, 18:22
  2. wheel spacer sizes?
    By Hawkes in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2011, 13:40
  3. Wheel spacer advice
    By Dan76 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th February 2010, 10:59
  4. wheel spacer recommendation?
    By imported_highlander1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2005, 14:58
  5. Wheel Spacer Bolts
    By imported_MancheS3er in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2005, 15:44
