EM TuningChris Nott
Like Tree1Likes
  • 1 Post By Wabby
Thread: Anybody with VCDS and a 2.0 TDI BKD Engine, willing to get a value for me?
    Oct 2011
    43
    If anybody has access to VCDS and have a 2.0 TDI BKD engine, please could you see what your values are in the following screen:
    Channel 5 of Adaptation on Engine.
    This channel holds the details for cold starts, and I think myn has been messed with - hence wanting a stock value if anybody has them?
    zippyijk's Avatar
    Dec 2009
    Dublin, Ireland
    70
    I'll get it for you this evening if no one has posted in the mean time.
    The wife has taken the car for the day.
    I read your other thread, you were able to search elsawin to find that problem? How did you do that?
    I've got elsawin but don't use it that much as I've to run it in windows virtual pc (xp mode).
    2005 Audi A3 Sportback 2.0TDI DSG S-line
    2012 Skoda Yeti 1.6TDI Greenline II Elegance
    Oct 2011
    43
    I just browsed:
    Technical Product Info > Engine > Function > Engine problems involving starting behaviour > Cold engine difficult to start, misfires and has white smoke.
    Low and behold, my exact symptoms, and my engine code and year is the exact requirement for resolution by ECU software upgrade.
    IF I can make relevant changes using VCDS I will, otherwise its a trip to the dealers with my pants down!
    BUT: Anything is better than my first assumption of porous/cracked cylinder head :D
    zippyijk likes this.
    zippyijk's Avatar
    Dec 2009
    Dublin, Ireland
    70
    Yeah definitely!
    I had the porous head problem, got it fixed but cost a fortune
    It not the cost that annoyed me its the fact I could have gotten a load of mods done with that money
    Cool, I'll try that out next time. Didn't realise you could search like that in elsawin.
    zippyijk's Avatar
    Dec 2009
    Dublin, Ireland
    70
    Right went to check it there but getting a security access error for that channel. Do you know what the security pin should be or how to get it?
    Oct 2011
    43
    Its OK now mate. I have discovered that I cannot change that value on this ECU anyhow - It seems to vary based upon the previous starting conditions.
    Trip to Audi for the software update me thinks.
    Cheers anyhow mate
  1. Replacing 2.0 TDi engine: 140hp BKD with 170hp BMN
    By zaibzonline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th August 2013, 22:53
  2. Turbo charger - standard 2.0 ltr TDI 140bhp BKD engine
    By tdi-man in forum For Sale/Wanted - Audi Parts
    Last Post: 7th October 2011, 13:39
  3. 2006 A3 TDI sportback BKD 140 engine oil filter?
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th March 2011, 11:31
  4. (BKD ENGINE 2.0 TDI ) PANNEL AIR FILTER
    By N16KSH in forum General Automotive Chat
    Last Post: 3rd February 2011, 14:56
  5. Clutch question TDI BKD Engine?
    By V16 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th October 2010, 22:27
