Chris NottEM Tuning
Thread: Fault help
    s3ollie's Avatar
    Jan 2007
    749
    Fault help
    Hi, I recently changed my steering rack as the old one had some serious play.
    I got a new brand new one that is for a TT pn 8J2423055D.
    I am now getting this fault code and am wondering if the coding is incorrect.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0021128
    Shop #: WSC 06314 000 00000
    VCID: 72E059E21429
    1 Fault Found:
    01309 - Power Steering Control Module (J500)
    008 - Implausible Signal
    I had to do the adaption holding for five seconds left right etc... to get the assist to work but it all appears to be working fine appart from the fault code.
    Does anybody know what the problem could be?
    8P S3
    Fossie
    Rhubarb Triangle
    3,961
    Not familiar with the problem mate but see if this helps :- 01309 - Ross-Tech Wiki
    s3ollie's Avatar
    Jan 2007
    749
    Thanks for the that mike forgot about the wiki.
    Do you know what is meant by : Steering Aid Characteristic Settings?
    I had a look but, other that the coding im not sure what other settings i can change
    8P S3
    Lewis583's Avatar
    Mar 2010
    834
    Could mean the level of assistance given by the electric power steering, or how the steering gets heavier the faster you go.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by s3ollie View Post
    Sorry mate - I don't have an S3 and I don't think the 2:0 tdi has 'steering aid' so can't help ! Someone will be along shortly to help I'm sure.
    s3ollie's Avatar
    Jan 2007
    749
    All sorted now thanks for the help. I had the DSR turned of in the assistance module for some reason.
    Any body know what the driver steering recommendation does? Is it what varies the assistance so the steering is lighter when parking etc...? Because mine was doing that when it was turned off anyway
    8P S3
  1. Replies: 2
    Last Post: 19th December 2010, 20:41
  2. I have a Fault!
    By EAGLE79 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2008, 18:30
  3. ESP Fault, Steering Fault - Re Retro Fit Cruise! Help Please
    By J7-AUDIA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2008, 12:17
  4. A4 Concert fault - Amplifier fault ??
    By v1nny in forum In-Car Entertainment
    Last Post: 12th November 2006, 02:51
  5. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
