JMB RetrofitsEM Tuning
    v1raj's Avatar
    Apr 2009
    279
    EMTuning - Audi A3 DPF Delete Package
    So for the past couple of weeks my DPF sensor has been throwing up errors on the DIS. I had gone through the various methods of clearing the faults.. Some days it worked, some days it didn't. So, i decided to get the DPF removed.
    EMTuning (Welcome To EMTuning - ECU Tuning, Vehicle Lighting, ECU remaps, HID and LED Lighting Kits) are local to me so it was a natural choice to chose them, plus having an excellent reputation for quality maps and customer service.
    They guys were friendly and helpful in discussing the various options available.
    The total work lasted around 3/4 hours. This included:
    The labour to remove and fit the DPF.
    Removal of errors produced.
    Installation of remap to suit needs.
    The end result is amazing! The car is now pushing 215-220bhp and 330lbs of torque. Gear changes appear to be smoother, revs go all the way to redline instead of maxing out at 4k. Fuel economy seems to have improved too. I regularly commute to Nottingham from Northampton (75 miles) and used to see on average 48-50mpg each way. Since the delete, 55-57mpg is quite easy to achieve.
    Total package was £569 - quite a bit cheaper than many other companies so that was an added bonus
    Pros:A lot more power
    Smoother gear changes
    Better fuel economy
    Cons:
    Tad more smoke
    Very tempting floor it
    All in all im more than happy with the new setup and can’t recommend them enough!
    2006 Audi A3 (8P)
    Spec - 2.0 TDI l DSG l Sprint Blue l Leather Interior l 18" RS6's | H&Rs | S3 Front | 6k Bi-Xenons | EMTuning DPF Delete Package
    Plans - BBS
    Rob-Quattro's Avatar
    Sep 2011
    Cambridge
    207
    Brilliant write up! Glad your happy with the results! Makes me want it done even more! Will wait to see if the new MOT rules say DPF deletion is passable first.
    Lava Grey A3 Hatchback S-line 170 Quattro, 18" Speedline Turini's, Bilstein B8 Shocks, 35mm H&R Springs, H&R ARB's, Small Remap, Darkside Development EGR Delete, K&N Panel, Full S3 Brakes, Yellow Stuff Pads, Drilled/Grooved Disc's, Bi-Xenons, DRL's, Full Leather, RNS-E/Changer/Bose, LED Interior Light Pack + Ambient Lighting, Rain And Light Pack, Rear Parking Sensors, Cruise Control, Auto Folding Mirrors, Black Grill/Badges, MY11 Rears, Lamin-x Fogs.
    Aug 2008
    Manchester
    130
    Is your turbo a bit noisier now? Had mine done and can agree with all of the above, but do get a bit of a whine/siren-ish noise, not too loud though. Been told it's almost certainly due to the exhaust gasses resonating in the downpipe which is now open without restriction, but still a little concerned given the number of these that go wrong -turbos, injectors etc.
    Definitely finding i'm using the paddles more on my s-tronic but loving it!
    Rob - most use the original parts, just literally remove the filter and weld it back up neatly so they'd have to open it up to check = MOT no problem.
    Chappy's Avatar
    Call me Dan :)
    Sep 2010
    Grimsby, UK
    450
    That is cheap! I will seriously consider it after the new MOT rules are confirmed.
    Be interesting to see how it performs on a newer common rail engine
    AudiA3 2.0TDI S-Line
    Phantom Black | Leather Seats | Heated Seats | Black Optics | AMI | Badges Deletion | Rear Sunblind | Armrest | Darkened Glass | S3 Chrome Grill | H+R 10mm Spacers up Front | H+R 13mm Spacer at Rear | Mtec Cosmos Blue Bulbs | Cared for Paint Work |
  1. DPF delete and remap questions
    By Adnic69 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th August 2012, 21:14
  2. A3 quattro DPF Delete Pipe
    By eddyd in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th August 2011, 21:17
  3. 2.0 TDI 170 CR - Remapping? DPF Delete?
    By SleeD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2011, 07:46
  4. DPF Delete for a 170 TDI Quattro Help?
    By MOOSH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2011, 18:42
  5. DPF delete on a Quattro
    By Tilly in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th April 2010, 08:56
