Monster MotorsportEM Tuning
Results 1 to 12 of 12
Thread: CH/LH LiGHTS
    Yaseen1991's Avatar
    Aug 2011
    102
    CH/LH LiGHTS
    Hello again, i no this has been coverd before but i cant find the correct post
    Neway just had the rear facelifts adpated to work as they should (Thanks NAD, what a top guy!) he also enabled the ch/lh function but there not working :S
    He did mention i need to earth a wire or something, but cant find the post, i did see that it might have something tp do with a switch :S
    Just wondering if ne1 can shed any light on the situation and what i need to earth
    josiah2007's Avatar
    Coasting
    Jul 2010
    London
    66
    Quote Originally Posted by Yaseen1991 View Post
    Hi Yaseen, I also enabled this feature to my car about 6 months ago. It was pretty easy when I followed this link below:
    cominghomelights - Audi Retrofit
    It has a picture of the earth point which should be useful to you.
    Jun 2011
    Roslin
    105
    Josiah2007,
    Is the repair wire an Audi part or is it a case of making one up?
    Cheers,
    S
    josiah2007's Avatar
    Coasting
    Jul 2010
    London
    66
    Quote Originally Posted by SWILKO View Post
    Josiah2007,
    Cheers,
    S
    Mine was made up - a piece of wire with the ends slightly stripped! Cheap n' easy!
    Yaseen1991's Avatar
    Aug 2011
    102
    Cheers josiah2007. Gonna hav a crak at it first thing tomorro morning!
    josiah2007's Avatar
    Coasting
    Jul 2010
    London
    66
    Let us know how you get on!
    Jun 2011
    Roslin
    105
    Cheap n easy sounds good, cheers J....
    Khufu's Avatar
    West coast of Scotland
    5,693
    There is also a multi earth point just under the carpet of the wheel arch under the fuse box, makes for tidier wiring.
    Jameze's Avatar
    James
    Jul 2011
    Leeds
    505
    Is this all it takes?? That has got to be the easiest mod ever after switching the interior bulbs to LED's!
    Is there any limitations to this? I was keen to do this a while back but decided against it after I heard there was repair wiring involved (in my head it was much more complicated than this!). Basically... will this work in my car? MY10 with Xenons (as per sig).
    May 2010
    Oslo, Norway
    142
    AFAIK if you have autolights/rainsensor, its only vagcom needed on the my09+. If u do not the autoswitch ur screwed, unless you retrofit..
    2010 SB TDI - Accuair E-level - Air Lift Slam front and rear - Bentley CGT 9 spokes - Votex hatch spoiler - S3 front and rear - RNS-E mk2
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Just go to audi and ask for a repair wire 000 979 009. Only cost about £2 max. Then just strip one end. Follow the instructions in the link already provided. You will find connector E with the other connectors under the drivers side panel to the right. They are all marked with letters. Can be a bit fiddly to get out! There is a red tab which secures the connectors, you need to pull this away, then you can release the connector.
    Once all coded, you may find the ch/lh does not work. Just unplug the and re-plug the connector and all should be good!
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    438
    Quote Originally Posted by grimp View Post
    So unlike the older models, you must have the auto-lights switch on the MY09+ in order to get CH/LH lights?
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
  1. Replies: 6
    Last Post: 23rd August 2011, 12:48
  2. Retrofitted handle illumination, warning lights and puddle lights
    By Joereynolds89 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2011, 01:31
  3. Coding to turn on rear lights with front daytime running lights
    By TreborA4 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 6th April 2010, 21:54
  4. Puddle lights and hazard lights fix (on doors)
    By trs888 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2010, 08:18
  5. Daylight running lights no rear lights ?
    By gradwells in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th September 2009, 12:39
