MAP Sensor location??
Hi Mate the Map sensor is located below the oil filter housing on the turbo pipe you will have to remove the air intake top cover situated at front of the air filter housing, then you need to remove the ducting which is U shaped once this is removed you will be able to see the MAP sensor which is secured by two screws be careful removing the screws so that you dont drop them as they tend to roll under the engine on the engine undertray and are very hard to retrieve without removing the undertray. Hope this helps Cheers
