JMB RetrofitsChris Nott
    Apr 2010
    Nottingham
    230
    S3 Xenon dipped beam level
    Hi,
    Is there any way to check that my auto levellers are working correctly via VAGCOM or any other means? Now that i've started driving around in the dark i've noticed that the light beam seems a bit low compared to my old mk4 Golf. It's an '07 S3.
    '07 Phantom Black S3
    Superchips Bluefin Stage 1
    TTRS FBMFSW
    MY11 Rear Lights
    Auto-lights/Auto-Wipers/Auto-dimming rear view mirror/CHLH retrofit
    Khufu's Avatar
    West coast of Scotland
    5,693
    you can go into the level module (55?) and perform tests. It gives you the option to put them all the way up, down & factory default
    Apr 2010
    Nottingham
    230
    Ahh, thanks. Will give it a go tomorrow.
    TTRS FBMFSW
    MY11 Rear Lights
  1. How to keep dipped beam on when using full beam???
    By Keithsri in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th August 2010, 21:31
  2. Xenon dipped beam - down, switch off, normal again??
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2010, 08:59
  3. A4 Dipped beam bulb replacement.
    By LaSarthe&Back in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2007, 22:18
  4. Sounds silly BUT is high beam brighter than dipped beam......
    By A3-frankie in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2007, 18:15
  5. Bulbs used for dipped beam S3 headlamp
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2006, 22:08
