I'm pretty sure they will fit physically (most of rear suspension is identical between FWD & 4WD) but they wont be right rating for the weight over the axles. The S3 will be heavier over the rear due to the hadex & driveshafts etc and will so need a stiffer spring. Not sure about the difference in front axle weight comparison.
