19" wheels with 235/35/19 tyres any rubbing issyes?
Kash3838
Cardiff
i wabt to upgrade my s3 8p to 19" alloys - 8.5 x 19 et45 with 235/35/19 tyres
will they cause any rubbing on front and rear with standard suspenion set up?
if you dont lower it you "shud be ok " fella , its the rear that will rub the most
is your car lowered?
I have 235 on my front but had to change the rears for 225 when i lowered 45mm
I have a standard ride height s line and fitted 19" with the same tyres and not had any problems. Does make the car look even higher though! You can lower it without rubbing aslong as you have 215 35 19's fitted (225 if your not decking it)
As said fella you will be fine on standard set up. Sure N8 will be along to confirm anyway. What alloys you getting? I see your car quite alot parked outside your company looks good ;)
It's standard set up, dunno about lowering it..... Hmm
If I do I'll opt for 225 instead. As fir the rims there are a couple I like. Not 100% sure yet.
I think I'll get the Tyres in 1st.
Ash seen ur car too, looking good. I'm getting bored so need to do something to the car.
