Chris NottSky Insurance
Results 1 to 21 of 21
    Jun 2011
    Wellingborough
    1,127
    Lightbulb HELP NEEDED - 2009 number plate LED's
    Hi All,
    as some of you know i supply LED bulbs, but there is nothing for the 2009+ A3 without having to use resistors.
    so i was wondering if anyone would be able to help me out with some ACTUAL readings of the current that the car gives when the plate lights are on, you would need a multi meter to help.
    i would need 2 readings from the 1 car,
    car turned on with plate lights on.
    and car off with side lights on.
    if i can get more than 1 person to do this then i can see that the cars are running the same and i can submit these readings to the factory and they can make me the bulb with the higher resistants so it dont through an error on your DIS, and you wont have to use the external resistor.
    if i can get 2 members having a go for me then there will be a free pair of the new numberplate LEDs in it for you...
    would like it ASAP so i can get the testers in before the end of next week and then if successful then get a batch in to supply members with the 2009+ cars that are wanting to do this mod.
    Trups
    Jameze's Avatar
    James
    Jul 2011
    Leeds
    505
    AFAIK I don't have a multimeter but if I can source one from someone then I'll get back to you! I'll ask a few people who might have one I can borrow.
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,083
    I SO want some of these Trups!! Will definitely be ordering some from you when you crack it. xx
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    Jun 2011
    Wellingborough
    1,127
    Thanks guys, cant crack it unless i have some readings from a couple of members!
    they should hopefully be no more than £10 a set depending how much the factory charge me for the modifications in the resistants but i can do a good deal for all.
    just hope we can get some in the next few days so i can get them over to me to test in a car and then il get the batch in!
    slade777's Avatar
    Sep 2010
    763
    Same as Paulie all the lights I've ordered so far from Trups have been top notch!!!
    Current:
    A3 Black Edition 2.0 TDI 140
    Sep 2011
    South Carolina
    I live in the states and got my LED bulbs from ZIZA they have a heatsink built in and are polarity sensitive bulbs.. I haven't had any kind of bulb trip errors whats so ever on my 2009 a3 Audi A3 FWD 2.0T > Lighting > LED > ES#252856 A3 LED License Plate Bulbs - Pair - T10W37KT-10 This is where I got mine
    Jun 2011
    Wellingborough
    1,127
    still no one yet
    slade777's Avatar
    Sep 2010
    763
    Quote Originally Posted by t8ups View Post
    still no one yet
    If you don't get any luck I'm 40 miles away could maybe drive up one day so you can test on my car!!
    Current:
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    438
    Trups,
    I have a mate with a 10-plate Sportback. If I can meet up with him I'll try to get some readings for you.
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    Jun 2011
    Wellingborough
    1,127
    Quote Originally Posted by JordanFostersSN View Post
    is yours the facelift 2009 model or the pre facelift?
    Jun 2011
    Wellingborough
    1,127
    Quote Originally Posted by slade777 View Post
    That would be cool Lance, we will keep an eye to see what happens as i want this moving asap so you can all get the bulbs in ready for the darker nights.
    Jun 2011
    Wellingborough
    1,127
    Quote Originally Posted by ryanstewart9 View Post
    Trups,
    Ryan, that would be awesome if you could, like i said in the OP, if i can get two readings then there will be a free pair in it for you.
    i also posted the other bulbs and lamp back out today so keep an eye out in the post.
    Trups
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    322
    I've not forgot about you mate, my mate at audi is gonna test one for you when he has on 09 plate to work on!
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
    wesley's Avatar
    Feb 2007
    Manchester
    322
    Says in the Ad that they will trip the warning light on 09 onwards!
    'Featuring built in resistors, making these a simple plug and play procedure
    Some 2009 and newer models will trip a bulb out error code'
    Jun 2011
    Wellingborough
    1,127
    Quote Originally Posted by wesley View Post
    Thanks Wez.
    if there is anyone local to me i am happy to take the reading off your car if you will let me?
    May 2010
    Oslo, Norway
    142
    i would very much like to help you out, ill see if i can get my hands on a multimeter
    2010 SB TDI - Accuair E-level - Air Lift Slam front and rear - Bentley CGT 9 spokes - Votex hatch spoiler - S3 front and rear - RNS-E mk2
    Chappy's Avatar
    Call me Dan :)
    Sep 2010
    Grimsby, UK
    449
    My car is 58 plate, does this mean I also can't have LED plate lights?
    AudiA3 2.0TDI S-Line
    Phantom Black | Leather Seats | Heated Seats | Black Optics | AMI | Badges Deletion | Rear Sunblind | Armrest | Darkened Glass | S3 Chrome Grill | H+R 10mm Spacers up Front | H+R 13mm Spacer at Rear | Mtec Cosmos Blue Bulbs | Cared for Paint Work |
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,083
    Quote Originally Posted by Chappy View Post
    Not necessarily, Chappy as I believe 1animal1 has LED number plate lights that work perfectly in his facelift S3, which IIRC is an MY09 also. Get in touch with him and he might be able to tell you where he got them from. x
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,397
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    Do you still need these readings bud?
    I might be able to get mine out this week. I can measure my 59plate and my 61plate (when it arrives)
    Jun 2011
    Wellingborough
    1,127
    yes i still need some reading if you can get me them, i need the reading in Volts.
    Thank
    Trups
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,457
    Just had led puddle lights ,led map lights,led footwell lights ,led interior lights ,led number plate all working perfectly ,, thanks to t8ups , robina3 and my best mate wesley for fitting everything fantasic job....
  1. 2010+ Number Plate LED's - Sorted
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th August 2012, 11:33
  2. The Number Plate LED's
    By Smoothie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2011, 10:41
  3. MOT with Number Plate LED's
    By Maq in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd December 2010, 19:59
  4. Number plate - help needed
    By Brooksy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2010, 09:41
