JMB RetrofitsEM Tuning
    Oct 2011
    9
    What sockets for DIY 8P front wheel bearing change ?
    Hi, I have an Audi A3, 2.0l tdi 140, the car is on a 2004 plate, 8P?
    The front wheel bearing has gone, i bought one locally and it came with a new hub bolt and four bolts to secure the hub but i need help buying the correct sockets for the job.
    The hub bolt is 12 sided, around 24mm??? , maybe metric???, can anybody advise me on the correct socket required.
    The hub itself came with four bolts that secure it, they have a 12 sided pattern going into the head of the bolt (male), again i have no idea what size of socket i need to buy so i can get the bearing changed, please help, thanks...
    Oct 2011
    9
    Anyone ???
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    653
    24mm for driveshaft.
    Oct 2011
    9
    Ok, after some digging i found the required info. For future reference it is as follows...
    Required tools:
    21mm Socket - for removing brake calipers
    12mm triple square socket/bit - to remove 4 rear bolts on wheel bearing/hub
    T30 socket/bit - to remove rotor from hub
    27mm socket - to remove axle bolt
    *** Some have a standard hex bolt and some have a 12 point bolt head. Make sure to check your specific vehicle. ***
    3 inch extensions for ratchet
    Rubber mallet - to pound out axle from wheel hub(not shown in picture)
    Torque wrench with capable range from 35-150 ft lbs.
    A breaker bar to remove a seized axle bolt - these usually only come in 3/4 socket size so a 3/4 to 1/2 reducer will be needed.
    Oct 2011
    9
    Ok, just bought all the tools i didn't have, one adjustment to the above is that the wheel hub bolt is 5/16 th in size with 12 splines inside it, a 24mm fits but it is a bit loose, hope this info helps someone else down the line...
  1. front wheel bearing 2.0 tdi part number??
    By kaos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2011, 23:53
  2. A3 2.0FSI Wheel Front Bearing
    By Maverick001 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th November 2010, 17:27
  3. Anyone had a new front wheel bearing fitted on their A3?
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2010, 18:38
  4. Front Wheel Bearing/Hub Assembly
    By gavinsky23 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th February 2010, 18:40
  5. DIY S3 Front wheel bearing....
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2009, 21:32
