AH FabricationsBadger5
Results 1 to 26 of 26
Like Tree1Likes
  • 1 Post By Wabby
Thread: Possible Head Gasket / Cracked Head Problem?
    Oct 2011
    43
    Hi Guys,
    I have a 2004 A3 2.0 TDI (BKD) engine with a suspected coolant related fault.
    The car is difficult to start when its been left over night, and seems to be loosing a header tank amount of coolant every 2 months or so. Now I read that this could be head gasket for the head being porous/cracked?
    I have checked the code on the head and its suffixed with 'B' not 'A' like most of the faulty heads, although I do read in some places that some 'B' heads were also faulty.
    Is there any checks, other than whipping the head off that will confirm if its gasket or the head itself?
    Would K-Seal have any affect on either of the two outcomes?
    Other than the difficulty to star when its been left, the car is fine. Runs ok, idles ok etc etc.
    Cheers for any help guys
    Fossie
    Rhubarb Triangle
    3,969
    Sorry to hear you have the problem. If it was a head gasket the temperature gauge would be off the clock whilst running due to the coolant being superheated by the cylinders. As the car is running normally I'm afraid it looks like a porous head.
    K-seal is always worth a try at £7 a bottle and will certainly help albeit not cure the problem.
    Yours is a very early 'B' suffix head so unfortunately it looks like you've been unlucky.
    Aug 2008
    408
    Check the dipstick for mayo like substance m8, if waters
    Mixing through the oil you will see it on dipstick hth
    Cal
    Mar 2011
    Wolverhampton
    125
    K-seal ftw!!
    2006 A3 2.0 TDI Quattro S-Line l Team Heko Wind Deflectors l Celtic Tuning Remap l Rear De-Wiper l Pipercross Panel Filter l
    After a Passenger Xenon Headlight for A3 8P. No ballasts required. PM ME!!
    Oct 2011
    43
    Cheers for the replies guys.
    The coolant is definitely not leaking into the oil, and its not using any oil. A friend noticed the coolant usage whilst changing a ECT for me, and this led to a theory of it leaking into the cylinder(s) causing difficult starting; A quick Google later and it appears that I am not alone!
    Will chuck some K-Seal in tomorrow and see how it goes. Hopefully it will start to start normally when cold, which is the only issue the vehicle has at the moment.
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by asasprey View Post
    K-seal ftw!!
    Sorry asasprey - due to being a pensioner I'm not familiar with ftw! (seriously)
    I know WTF etc. etc. but please give me a clue.
    As far as K-seal is concerned it sorted my 2006 BKD and I no longer top-up coolant at 77k.
    Oct 2011
    43
    FTW = For The Win
    K-Seal is getting good reviews regarding the issue, so I should be able to post back soon with news of easy(er) cold starts
    Fossie
    Rhubarb Triangle
    3,969
    Thanks Wabby - I couldn't get my old head round that one !!
    Just make sure you follow the instructions and give it time to flow through the system. I contacted the manufacturer before I used it just to check out the theory and they confirmed that, although it was designed to plug leaks, the way it works is ideal for the 'porous head' problem and could only help the situation.
    Hope it helps you. Cheers
    Mar 2011
    Wolverhampton
    125
    You crazy old people! Lol
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    You could try this stuff. I know nothing about it and never used it.http://www.steelseal.co.uk/
    I
    t`s cheaper on ebay if you want to buy it.eBay - The UK's Online Marketplace
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Oct 2011
    43
    I chucked some K-Seal in the expansion bottle, and so far its starting to work.
    This morning it started after 2 seconds on the start motor - normally takes 8-10 seconds; so its starting to do its job.
    From what I read I need to give it a good few days to resolve the issue as it has to get from the expansion tank to the cylinder which will take as long as the coolant takes to seep into the cylinders?
    Good results so far anyhow - will report back soon
    Graham89 likes this.
    Feb 2011
    Leeds
    58
    Quote Originally Posted by Wabby View Post
    Hi Mate, I have had this exact problem with my 2004 BKD 2.0 sport, i used K seal and it really helped and I dont get any water mixing with the oil but I am topping coolant up every few days and now it is struggling to start from overnight as there must be water getting in the cylinders again, I am going to have to bite the bullet and get a new head at some point but I know it will cost me well over a grand, let us know how you get on though!
    Feb 2007
    1,257
    Below is a picture of a head i removed which shows the usual place the head cracks. If your having starting problems with water getting into the cylinders your screwed as K Seal will not stick the high pressure in the head and just blow out.
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    I used K-Seal for my BKD coolant loss issue, I was loosing around a bottle every 2 weeks and it would struggle/miss fire when starting first thing in the morning. Now starts and runs fine. 20k miles and a year later its worked. Not topped up once since i used it so for now it's sorted. It may not be a permanent method but it sure gets some more pennies worth out of the 'dodgy head'. Good luck.
    MTW
    MTW's Avatar
    Feb 2011
    212
    im getting the same problem exactly, where abouts can i get k-seal from?
    Fossie
    Rhubarb Triangle
    3,969
    Halfords, Motosave or any decent car accessory outlet. Approx £7
    MTW
    MTW's Avatar
    Feb 2011
    212
    ah ok, cheers mate
    dex140's Avatar
    Dec 2009
    190
    Copuld it possibly be your radiator? Mine went two months ago...maybe worth getting the cooling system pressure tested?
    Oct 2011
    43
    Does anybody on here sell recon heads for these BKD engines?
    K-Seal doesnt seem to have had an effect.
    Fossie
    Rhubarb Triangle
    3,969
    Check out 'devonmikeyboy' on here but first you have to give k-seal a few days to work.
    Oct 2011
    43
    Its been in now for 4 days. The morning after I put it in it started very well, but since its gone back to how it was.
    For the sake of another £10 I will try another bottle of the stuff - but after that its going to have to get sorted. Its doing my bloody head in! lol
    Fossie
    Rhubarb Triangle
    3,969
    Why don't you PM the guy and see what he has available ? He will help if he can.
    Good luck !
    Edit: check out post #13 on this thread !!!!!!!!!!!!
    Oct 2011
    43
    Ta. Will PM him when I have 15 posts and can PM
    Fossie
    Rhubarb Triangle
    3,969
    Only one to go then mate ? Answer this and you've cracked it !!!!
    Dec 2011
    MIDLANDS
    241
    i have this coolant loss problem also. however i dont have any start up issues, there is no sign of oil in water or water in oil, and there are no signs of smoke. it is a 2007 bkd engine with the "C" code cylinder head. i have not seen any signs of water under the car any suggestions??
    i think im going to get my mechanic to pressure test the coolant system tomorrow.
    will this be covered under any kind of manufacturers warranty??
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    tdi-man's Avatar
    Jul 2009
    1,611
    This is what happened to my head with part number C.
    use to loose a little water but the water pump was leaking.
    what happends if cracked between glowplugs
    Quote Originally Posted by devonmikeyboy View Post
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
  1. CRACKED AMK HEAD!
    By stoneys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2010, 22:30
  2. Cracked AMK cylinder head
    By Sandip in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2010, 20:13
  3. Head gasket/ cylinder head worst nightmare!
    By lugz in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2010, 15:52
  4. HELP HELP... Coilpack cracked in head ???
    By imran62@gmail.com in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th October 2009, 10:58
  5. Cracked head, can anyone help or advise?
    By James333 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2008, 10:52
