Badger5Volks Autos
Results 1 to 8 of 8
    Apr 2010
    Help needded with 2.0 FSI A3 2003
    Whilst driving on the motorway at 70 my car seemed to misfire and loose total power so i pulled over to the hard shoulder and even when revving the car in neutral there was no power it was almost like a limp mode. i switched the engine off and waited 5 mins and the car was back to normal for about 5 mins and then it happened again.
    so i got the car home and scanned it with VAGCOM and a whole host of errors:
    6 Faults Found
    18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
    P1696 - 002 - Lower Limit Exceeded - Intermittent
    16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    P0011 - 008 - Implausible Signal - Intermittent
    16814 - Catalyst System; Bank 2: Efficiency Below Threshold
    P0430 - 002 - Lower Limit Exceeded - Intermittent
    17443 - Sensor for NOx (G295): Signal Implausible
    P1035 - 008 - Implausible Signal
    16575 - Fuel Pressure Sensor (G247): Implausible Signal
    P0191 - 002 - Lower Limit Exceeded - Intermittent
    18974 - Low Pressure Fuel Sensor (G410): Short to Plus
    P2542 - 001 - Upper Limit Exceeded - Intermittent
    Readiness: 0000 0000
    I have cleared these errors and the car seems to be ok but there is now one error which won't go off which is:
    1 Fault Found
    17439 - Intake Manifold Tuning Valve (N316): Setpoint Not Reached
    P1031 - 004 - No Signal/Communication - Intermittent
    Readiness: 1110 0101
    so i have now opened my intake manifold and its pictured below: it doesn't look like its closing properly but its not seized i have cleaned it up and replaced it for now.
    would this have caused the problem? i also took out my spark plugs and they looked like this:
    Would it be safe to say that i need a new intake manifold flap motor? i have also noticed that when i rev the car while driving or in neutral i get a sort of zzzzzz noise i noticed this noise also when i was on the motorway. it gets louder web i accelerate or rev the engine..
    Please can anyone advise?
    Khufu's Avatar
    West coast of Scotland
    5,693
    its pretty sooty surely? I dont think my throttle flap is like that, i'm not sure about plugs as i'm only soon due my 1st set of new plugs in November.
    It could need realigned:
    Throttle Body Alignment (TBA) - Ross-Tech Wiki)
    Apr 2010
    The inside is very dirty but the outside (first pic) is clean I would have thought the inside would be dirty?? Thanks for your input will read up on that
    Apr 2010
    Is the default position of the flap open or closed?
    Apr 2010
    I can't do a TBA as I need to have no error codes to do so and my car chucked out the error
    Apr 2010
    anyone???
    Khufu's Avatar
    5,693
    You could try disconnecting the battery for 30 mins & then try clearing the fault again. We had this on a Saab whose battery had gone flat & jump starting it left the sensor out of position. It wouldn't clear using our lead so we disconnected battery & let the modules totally clear & restarted with a good 12V and it alighned itself properly this time.
    Apr 2010
    I will give that a try see if it works.. Thanks..
    I was thinking to open the intake manifold and checking the four flaps in there? What do you recon?
  1. 2003 b6 cab
    By dg3967 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th May 2009, 00:08
  2. looking to buy a3 2003/4
    By rasA4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2009, 12:33
  3. Who can fit the RNS-E to my 2003 S3?
    By Will. in forum In-Car Entertainment
    Last Post: 15th August 2006, 20:37
  4. 2003 A3 2.0 TDI
    By DaveS3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2004, 23:03
  5. New 2003 A3 (2.0 TDI)
    Last Post: 18th October 2003, 11:05
