AH FabricationsEM Tuning
    A3 Sportback 2.0 T FSi
    Jul 2011
    Congleton
    67
    Question VAG K+CAN Commander V1.4 Help
    I bought from eBay a USB Interface VAG K+CAN including full software version 1.4 (China), this is meant to cover Audi A3 up to 2007.
    I have installed the software on the laptop connected to the car and all I want to do is check the error codes.
    Anyone get any idea how to use this software?
    I have succesfully connected to the ABS, stereo but I can not connect to the engine or do a general sweep for errors.
    I have tried to find a manual for the software but have found nothing useful.
    I have downloaded V2.5, V3.0, V3.6 and V5.5 of the software also and have had no real success with these either.
    I really do not want to accidently re-program anything, just want to read my own errors if their are any.
    Any help would be much apreciated.
    Fossie
    Rhubarb Triangle
    3,961
    Try posting in the VCDS section of the forum mate - you may get a response but bear in mind that stuff from China does not always work the way you want it to or expect it to !!!
    Oct 2003
    up north...
    767
    this hardware/software is a pig to use - there is no help coding and no long coder section so you have to know exactly what you are doing.
    if you really only want the vcds recoding/error checking then you should look at getting vcds - preferrably a legit one too :-)
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
  1. I'm looking someone with vag commander etc near Liverpool
    By Danio in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2011, 21:43
  2. VAG Tacho / VAG Commander
    By kid-jensen in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th December 2010, 14:34
  3. Rosstech table to work with K+can commander ?
    By random101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2010, 08:27
  4. Vag commander on egay
    By benr in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2008, 23:11
Tags for this Thread
