Chris NottEM Tuning
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Do I remove the locking ring? Coilover question ...
    Basically my JOM coilovers dont go low enough up front, so Im thinking of an easy way of getting the little bit lower I want. I fielded the question of removing the locking ring that sits below the spring platform on another forum, and it was met with mixed opinions. Just thought I'd ask what people think on here?
    My thoughts are that the locking ring is there to lock the height of the main ring, but it'll be wound to the bottom anyway and the drop link mounting prevents the remaining ring from going any lower.
    Since it doesnt need to lock the height, the concern really is the 1 ring providing less support than 2 rings. Im kinda thinking though the worst that can happen is that over time the platform somehow doesnt take the weight of the spring and gives way. This clealry wouldnt be great, but should the worst happen the spring ends up droping a bit until the car rides on the bumpstop/ the spring is caught on the ARB mounting point anyway.
    Other people have removed with no issues and I know many brands of coilover only run one adjuster ring anyway, so should I just stop worrying and do it?
    A pic to make it easier to understand ...
    Apr 2012
    526
    Any more on this as I have the same problem want it lower ??
    Apr 2012
    526
    Would the quartto ones make the car sit higher than non Quattro ? As I think the place I g or mine sold me the wrongs ones
  1. Coilover question
    By Gavlar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd March 2011, 20:11
  2. How do you remove steering slip ring?
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th November 2010, 18:44
  3. Coilover Question
    By ScottyBoy in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th June 2006, 23:04
  4. fk coilover question
    By 1mran in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2006, 17:01
  5. coilover question
    By cyuen in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 13:25
