AH FabricationsEM Tuning
Results 1 to 15 of 15
    Sep 2011
    MFSW install Guide?
    Hi guy's i'm new to the forum but like many people have been browing and reading-up for months.
    I was hoping there was a guide for retro fitting MFSW but other than lots of posts regarding parts,
    i can't find anything....
    I have an A3 8P with the wrong steering ecu but I have now bought the correct ECU to fit along with
    the new MFSW and airbag cable. No doubt i'll figure it out but i'd rather read a guide first so i don't
    break anything! lol
    If anybody can suggest a guide from somewhere or send a few pointers my way it would be appreciated.
    Cheers Guys!
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,572
    There isn't a MFSW guide that I know of but there are a few Cruise Control guides kicking around which involve the same steps.
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Rob-Quattro's Avatar
    Sep 2011
    Cambridge
    207
    Pablo.. How did you find out which ecu you required? Also a Guide is a brilliant idea!
    Lava Grey A3 Hatchback S-line 170 Quattro, 18" Speedline Turini's, Bilstein B8 Shocks, 35mm H&R Springs, H&R ARB's, Small Remap, Darkside Development EGR Delete, K&N Panel, Full S3 Brakes, Yellow Stuff Pads, Drilled/Grooved Disc's, Bi-Xenons, DRL's, Full Leather, RNS-E/Changer/Bose, LED Interior Light Pack + Ambient Lighting, Rain And Light Pack, Rear Parking Sensors, Cruise Control, Auto Folding Mirrors, Black Grill/Badges, MY11 Rears, Lamin-x Fogs.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    You need a Highline Steering ECU with the prefix 8P0 (8P being the chassis for the A3)
    Only Highline ECU's for the A3 that I know of are 8P0 953 549 F & 8P0 953 549 K
    Sep 2011
    Cambridge
    207
    I have a highline ecu, but no multi function.. It a straight swap?
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    It is indeed, providing the Highline ECU is prefixed with 8P0.
    Only parts you'll need is the MFSW itself and the new Airbag harness, which will allow you to plug in the MFSW, this part is about £20 from the dealers. You'll also need to code the MFSW in the Steering Wheel-16 channel and Radio-56 channel to accept the MFSW.
    Sep 2011
    Cambridge
    207
    You wouldn't have a part number for the Airbag harness would you? This goes for the S3 multi function wheel aswell as the standard multi function wheel?
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    Heres the part number for the Airbag harness: 8P0 971 589 Q
    Make sure you disconnect the battery on install
    Sep 2011
    Cambridge
    207
    Thanking you!!
    Shane.'s Avatar
    509
    Have you checked you have the correct slipring?
    STUFF FOR SALE: DLS R6 Midbass drivers, MFSW 3 spoke and Pioneer P88RS II
    STUFF FOR SWAPS:
    3 door A3 8P custom doorbuilds
    please contact for more info
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    Well spotted Shane. If you don't know what slipring you have post your current ECU you have installed and I'll be able to tell you if you need it changing. This is aimed towards Pablo, there will be no need for Rob to check as having a Highline ECU his slipring will be fine.
    Shane.'s Avatar
    509
    If not I have a multifunction slipring spare for sale (bought by mistake, for some reason I thought mine was wrong but it wasn't)
    STUFF FOR SWAPS:
    Sep 2011
    Thank you for the advice everybody!
    jb0o: i will get this info for you... skipping forward do you know if i can use my copy of VCDS-lite to change the two module codes after the install?
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    I dont think you'll be able to change any coding with VCDS Lite
    Sep 2011
    Thought as much, fortunately one of my friends has the full version. Again thank you for your help.
    Maybe a guide will come along at some point... lol :D
  1. FBMFSW fitted! (inc guide for mfsw to fbsfw)
    By ~RS~ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th March 2013, 20:29
  2. RNS-E, MFSW and Bluetooth install
    By AFN1980 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2012, 23:20
  3. VAG.COM Change after MFSW install
    By dinothetiger in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd August 2009, 07:04
  4. RNS -e How to guide to install guide and advice
    By 330_2_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2009, 15:15
  5. Install guide
    By Aspen in forum In-Car Entertainment
    Last Post: 16th January 2009, 12:41
