Badger5JMB Retrofits
Results 1 to 11 of 11
    l6rth's Avatar
    Mar 2011
    Cambridge, Cambridgeshire, United Kingdom
    85
    Angry Valve springs changed gat same problem
    Hi all,
    Some of you may know I have had my exaust valve springs changed,but to my disappointment the car still has the same problem,hesitation under hard acceleration,any ideas.warranty runs out tomorrow.seriously annoyed
    L6rth
    27,073
    It will still be covered as you have raised the issue within warranty, go back & say its still not fixed & if they argue warranty, which they probably wont, then state it was brought to them within, so they are obliged to rectify it.
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    coil packs,,plugs,,new diverter value, check hoses for splits , make sure your cai hose to turbo is on tight,,vagcom to check faults,,maf ,....
    l6rth's Avatar
    Mar 2011
    85
    The car was suppose to be checked after the work was carried out,they obviously did drive it properly.I was so annoy this morning I even contemplated p exing it,I've only had it 6 months.they only thing I liked the look of was a tts.anyway I'm not doing that but surely they would have vagcomed it before returning it to me.coil packs and plugs won't be warranty so is there a better set to get if that is the problem?what about a map problem?
    L6rth
    27,073
    Is it mapped & if so who by.
    Exhaust valve spring issue may not even show an error, it may show a misfire fault on cylinder 3, but then again it may not as some havnt had but had the same fault & recall work done.
    Look dont worry about these issues atm, get back to dealer, then see what outcome is before jumping to conclusions.
    l6rth's Avatar
    Mar 2011
    85
    The exaust valve springs in the head have been done,just annoyed it's been returned faulty so was wondering what it could be that isn't wWarranarty covered
    Thanks for the help
    No remap "yet"
    L6rth
    27,073
    Then you have to ask why did they do the springs for that fault if it isnt the cause, it was taken to them with that fault, how did they diagnose them being the issue is what mystifies me as if you notice the issue already then I bet they didnt road test it either at all or properly, its not fixed so go back, simples.
    l6rth's Avatar
    Mar 2011
    85
    I already emailed just to make sure,they didn't recognise the fault at first then I reexpained,the thing with the valve springs is that it is a product inhancement not a warranty job If that makes a difference
    L6rth
    27,073
    Enhancement my assssse, audi dont recall things to enhance, they recall due to there feck ups, it is warranty because it causes issues like this on these cars, my mates S3 doesnt show a recall for these, but he has the exact same issue, so tomorrow gonna swap out his plugs as they have changed his coils foc already, under a recall aswell, nope sorry meant enhancement lmfao.
    l6rth's Avatar
    Mar 2011
    85
    Let ,e know how you get on with the plug change,and what plugs you use
    L6rth
    gynads's Avatar
    Oct 2009
    338
    I had this issue, took it to REVO HQ, turned out it was a combination of the PCV leaking , so fitted a BSH blanking plug thing , but mainly was running too rich, i drove it home with the map leaned out and was way better.
  1. Diverter Valve Springs?
    By ross_broughton in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2010, 21:54
  2. Valve springs replacement - Audi TSB
    By GConn in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th January 2010, 08:03
  3. Possible N75 Valve Problem?
    By AU01 A4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2010, 19:01
  4. ECU changed, car wont start, immobilser problem
    By S4_dan in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th September 2006, 20:21
  5. bypass valve changed to blow off valve ??
    By imported_jpjp in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th July 2004, 23:53
