Sky InsuranceAH Fabrications
Results 1 to 19 of 19
    Aug 2010
    34
    Driven through flood water
    Hi drove through flood water last week, didn't realise how deep it was . Car starts fine but water has mixed with the oil. Possibly hydo-locked and ideas?
    2008 Phantom Black S3
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    Quote Originally Posted by brads View Post
    Hi drove through flood water last week, didn't realise how deep it was . Car starts fine but water has mixed with the oil. Possibly hydo-locked and ideas? Cheers
    If it starts,it isn't hydro-locked,but it's clearly damaged,and needs attention immediately...don't drive it further,as you may only make things worse.....get it to a decent garage immediately and get it looked at.
    Jul 2011
    Sampford Peverell
    131
    Agreed with S3alex . get it inspected asap as it could be fairly serious.
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    I dont get this ? whats the question ? how can it poss be hydro locked if it starts fine ? Is the level up on the dip stick ?
    How deep was the water and did you get a bow wave up to intake hight ( top of grill) ?
    Khufu's Avatar
    West coast of Scotland
    5,693
    Is the emulsion on the dip/expansion bottle stick or just the cap? I'd get some engine flush into it and get the oil changed ASAP. As said, it wouldnt start if hydro locked and you would know if that happened!
    Also got to watch going through flood water, the cold water can shatter the hot contents of your CAT.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Quote Originally Posted by Khufu View Post
    Is that why cats hate water ?
    Aug 2010
    34
    The car cut out just out of the water, I think the water went to the intake level. There is water eveident in the filler cap area and filler neck. Also on the dipstick. Just wondered how the water could be evident in the oil without bending anything? ps there was no water in the oil prior to the flood water damage.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    Point is,irrespctive of how the water got in there,it shouldn't be there,and whether it's something as simple as water ingress without any engine damge,you don't know how it's got in there,and if the water level went high enough to end up on the filler cap,then it went pretty high.....it needs someone to give it a decent look over.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    First thing is an oil change but unfortunately i would want to see a flushing oil through it first to mix up all the emulsified oil before its drained. Its no great shakes just more money. Change the filter as well.
    Aug 2010
    34
    Quote Originally Posted by S3Alex View Post
    Will do thanks just thought I would get some advice first, as I am unsure how the water would get into a sealed unit. Unless it is coolant caused by the floodwater somehow.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    It's not sealed though if you sucked it in through the air intake....
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Aug 2010
    34
    Quote Originally Posted by audicruiser View Post
    then would it not hydro-lock?
    Mar 2011
    Cleveland
    981
    And if you sucked it in the air intake, it would either lock up or blow it out of the exhaust as steam, depending how much got in. Can't see how it could get from the inlet to the oil unless you have no piston rings?
    Might have got in through a breather....
    27,099
    Do as Paddy & Ewan advise imho, empty the oil leave it to drain fully, flush engine maybe with some cheap syn oil, then refill to level with good stuff, check it then to see if anythings apparent, sounds like water got in via a breather pipe, if I get a chance I'll go have a nosey at an S3 8P I'm working on atm, to see what pipes it could of got into to mix with.
    Could check the intake piping to the IC, disconnect & check for water in them, maybe some in the IC itself, you never know.
    Aug 2010
    34
    Thanks for the replies, the car is at Audi now. They are a bit confused how it could get into the oil but we will wait and see.
    Khufu's Avatar
    5,693
    The water can get sucked in through the exhaust too, think about the 4 stroke cycle. This will be could why there is some in the engine but its not hydro-locked like you would get if it got sucked in through the intake.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,403
    good luck!
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Mar 2011
    Cleveland
    981
    No suction in the exhaust, mate! Inlet, compression, ignition, exhaust.
    Khufu's Avatar
    5,693
    on later thinking it couldn't get far enough back up the exhaust to get even past the CAT.
  1. Drain plug flood- HELP!!!!
    By markpw73 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th July 2010, 18:37
  2. Problem after driving through flood
    By Monsoon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2009, 14:36
  3. Water pump not belt driven on 1.8TQS
    By Bong Water in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2008, 12:20
  4. Help I have driven through a flood!!!
    By Jules in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th April 2007, 15:08
  5. Oh dear, there's a flood...
    By Fencemaster in forum A8/S8 forum
    Last Post: 16th February 2004, 12:53
