Volks AutosSky Insurance
Results 1 to 9 of 9
    Sep 2011
    New on here.. need help with engine ECU
    I have a 2004 Audi A3 1.6.. Engine ECU (part no. 03C906056AP/0261S02057) is staying live after ignition off so is draining the battery.
    I sent the unit to ECU testing who after a week said they could find no fault.
    I then called ECU Repairs who said that particular part cant be fixed or data transferred.
    I found a refurb part at Euro parts who reckon they can transfer the data from mine on to a replacent part for around £440 all in.
    Or, Audi can re code a replacement part if I manage to pick one up cheap and take a punt on it being ok.
    So, much conflicting info.. can anyone advise whats best to do?
    26,734
    Get replacement module, take it to audi to code it up, as they will need to do immo & attach vin no. to it aswell.
    Sportback owner
    Apr 2007
    France
    465
    Scotty, there is something fishy here. If indeed the ECU is staying on and draining ther battery, it would have been diagnosed by ECU testing quite easily by placing a meter in the power-in line. It could also be tested in-car for the same current drain by any competent electrician. Are you quite sure it is the ECU that is draining the battery? There are many other potential curent drains in the car which could be at fault. Suggest you may like to get an electrican to give it the once-over and confirm where this current is actually going. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    26,734
    Yeah tbh never heard of an ecu hanging power, then again anythings possible these days, common fault for this are oem radio's, they are synonymous for this.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Wasnt there also an issue with a revision of the can gateway module if used with phone prep?
    26,734
    The rns 510 is also an issue for golfs etc until a gateway is updated to newest, whats crap is you have to pay for it when vag should replace anyway.
    Sep 2011
    Had an ex audi guy tell me it's definitely the ECU draining it.
    Unit is still hot long after ignition off. Had the unit out for a week and there wasn't any drain.
    Might try and get a spare and take it to audi
    Cheers guys
    Sep 2011
    Arghh just spoke to Audi and said ECU is not causing the drain, it's probably relay somewhere??
    Don't know what to do next, although it's good if I don't have to fork out for a replacement unit..
    Sportback owner
    Apr 2007
    France
    465
    Scotty, what I would do now is the following. With the ignition off, I would go to the engine fusebox and carefully remove each fuse, and place a DC current meter probes across the internal fuse contacts. You need a current meter that can switch down to 1 or two amps. Then do the same thing with the passenger fusebox. Record any current drain, then look to see what electrical equipment is fed by that same fuse. You can do this test for free. It might just point you in the right direction. Good luck.
  1. Replies: 4
    Last Post: 2nd March 2011, 12:56
  2. Engine mount details for 2.0TDi BKD engine
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2010, 19:29
  3. Replies: 3
    Last Post: 10th May 2008, 12:57
  4. Replies: 8
    Last Post: 21st November 2007, 02:40
  5. Engine is fixed... follow on from engine and turbo is dead
    By PhilR in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th March 2007, 23:10
