EM TuningSky Insurance
    Sep 2011
    2008 A3 Radio Problem
    Hi guys
    Newbie here, my wife has a 2008 A3 Sportback 1.9tdi, out or audi warranty in March but has an RAC warranty. The radio goes of when driving after about an hour. I have been told that this is likely to be an ignition control module is this right? Also the RAC will only cover labour at £40 per hour and the only audi dealer in NI is £93 oer hour and they also want a diagnostic charge of at least £80 this will increase if no fault code is present.
    My question is does the ignition module need coded? And is this different form the ignition switch? Also is this likely to be the cause?
    Your help is much appreciated Audi won't offer goodwill as the car has left the dealer network for servicing was serviced by the non franchised dealer before we bought it.
    Oh and another thing, (in for a penny in for a ound) anybody know if you can retrofit the silver roof bars to an A3 sportback
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,087
    Having a look at a thread on here from last year, it looks like the radio is programmed to switch itself off if none of the buttons have been touched for an hour, but I don't know if this is what's happening to your car. Welcome to ASN, Dan! Paula x
    Symphony stereo switching itself off!
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    Sep 2011
    Thanks Paula read that one but it seems especially on the tt forums that it should only do this when the key is removed and when I spoke to audi today they confirmed it should stay on when the car is running, Its just the dealer (yes there is only the one) in NI will not even speak to you unless they see a credit or debit card on their table. And with projected cost comming in at £450 plus Vat and the RAC only paying half I am wondering is it somehting that my local garage cansort although they can't code the part if it needs it.
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,087
    That's really poor about Audi's attitude towards your problem Dan . I know there are a few members in NI, there might be someone with VCDS who will be able to help you out - for a beer or 2 -by giving your car a scan and seeing which - if any - fault codes it comes up with and this would give you a point in the right direction as to how to fix it, without Audi poking in the dark and charging you for the pleasure. Hope you get it sorted, Buddy. x
    Sep 2011
    Thanks Paula, on the bright side its proving easier to run and more reliable than her ST2 focus. And my company Mondeo is a 4 year old monster just had an inetrcooler and needs a turbo and flywheel, glad I'm not paying for that.
    27,043
    If its switching of after an hour then it sounds to me like the unit isnt seeing the cars network properly as of course its turning of to conserve battery, could be a radio or wiring issue, I dont believe its a steering module problem atm, but a scan would potentially help, to try & log onto the radio module 56 1st, if cant connect then thats your issue.
    I have a new radio for sale for far less than £450, infact I could sell you vcds to logon to the car & the radio for less than £450.
    PM if of use
  1. Radio problem
    By jolly14 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd August 2011, 19:34
  2. PLEASE help problem i have with A5 Alloys for A4 2008
    By lochandubh07 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th June 2011, 21:48
  3. radio problem help!!!!!
    By steely1987 in forum In-Car Entertainment
    Last Post: 1st July 2010, 21:08
  4. radio problem HELP!-
    By steely1987 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2010, 19:58
  5. AUDI A3 CONCERT DOUBLE DIN RADIO/CD 2008 ?
    By Digzz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2009, 12:55
