AH FabricationsVolks Autos
Results 1 to 11 of 11
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Cruise Control - Please can someone check the coding I've found is correct
    I'm just about to buy the stalk and cover to do my cruise retrofit, but after going through hours worth of Searches I've still not got a definitive answer that makes me feel confident enough to make the change with VCDS.
    The best answer I found so far is below. Is it not just a case of ticking a box for DIS with Cruise then? Is the code 11463 to login to the engine module the same for all models?
    I've bought my own VCDS from Nige, and I've done my LED rear lights plus a few other things, but I'm still nervous of making a change that could knacker my pride and joy.
    Can anybody who has done theirs confirm what they needed to change please.
    the coding needed for vagcom on 16 (Steering) after the physical fitting is:
    0004042
    The only digit I changed on mine was the 2nd to last digit - from a 1 (Board Computer, No Cruise Control) to a 4 (Board Computer, CruiseControl).
    After I did the following to login to the engine ECU:
    log in to engine 01
    select Coding II - 11
    enter 11463 in to the coding
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Whenever you go into change the coding, the first thing you should do is write down what the coding is before you start, or do a full scan and print it off. Then when you're ready to recode there is a coding helper pop-up which will tell you which digit to change, and what entering that digit will give you. As long as you make a note of the original coding, you can't go wrong because you just enter the original again and it will return the car to its original state.
    If you don't feel confident in tackling it yourself, there's plenty people on here who are more than good at doing this retro-fit for you.
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    Jul 2010
    Merthyr Tydfil, United Kingdom
    846
    that's the same code I used when retrofitting my cruise control the other month and its worked ever since
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Hi Dan,
    log in to engine 01
    enter 11463 in to the coding then do it!
    Message should come up with something like "engine module has accepted coding"
    Then yes, go to module 16 steering wheel and change second last digit to 4.
    Once all has been coded correctly, you can check in measuring blocks under module 16 steering and test all functions of the control.
    In the later a3's 2009 onwards you normally have to code the engine module using the long coding from the pop down menu, but this should not apply to you being a 2007 model.
    Remember when installed and coded, do a full scan and clear any faults that may have appeared during the install.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,571
    Dannys the man!!
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    That's brilliant, thank you so much everyone.
    I was just thrown by the 11463 code you have to enter. All the other things I've done have just been checking boxes, or using the long code helper, so it confused me a bit.
    Thanks again for confirming this for me, all really helpful answers.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Quote Originally Posted by jb0o View Post
    Dannys the man!!
    Have been taught by the best my friend.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Quote Originally Posted by danb986 View Post
    No problem fella, anytime.
    26,722
    As above mate.
    Also note when fitting the stalk, make sure its in the middle position when refitting slip ring or you could snap the small plastic yellow/white locator lug which is fairly important to be fully working
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,571
    As above mate.
    I was stumped with the slipring seemed to be really stiff on one of the first A4's I did.. ended up being because the indiactor stalk wasn't in the middle, lol.. lucky I didn't snap it!
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Thanks for the tip, you may just have saved me a really frustrating incident
  1. a3 8p cruise control instructions & vagcom coding?
    By fizz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2012, 14:17
  2. Cruise Control on 09 B7 - Binary Long Coding ?
    By Masterm8fo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th June 2011, 14:12
  3. VAG COM to check bhp and correct engine parameters?
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2010, 18:13
  4. Cruise control coding A3 8P
    By mattandrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th February 2008, 17:13
