JMB RetrofitsSky Insurance
    Mar 2010
    Slovakia
    Audi A3 2009>> halogen headlight bulb change
    Hi guys,
    i've just spent more than an hour trying to change the headlight bulbs on my 2010 a3 sportback without any success. although it is a small 1.6 petrol engine, there is literary no space in the engine bay for hands. i've hardly managed to turn that one cap to uncover the two bulbs but it seems impossible to pick the holder of the bulb and swap the bulbs. ive bought a pair of fancy cool blue osrams but i cant fit them in any ideas except going to the official audi service??
    2010 Lavagrau A3 Sportback 1.6/Morel Dotech 6/Mosconi 100.4
    Feb 2011
    Preston
    64
    Hey Mate,
    Some people have managed to change it from the engine bay but with difficulty and it doesnt help with fat hands like me.
    Easiest way is to jack the car up, undo the wheel arch liner and poke your head up through there. It think you need a torx 15-20 screw driver but dont quote me to that.
    I got away with undoing some of the torx screws near the top and the plastic clips and had enough room to change them.
    Hope this helps mate.
    Quote Originally Posted by erq55 View Post
    Hi guys,
    Chris71's Avatar
    May 2011
    Deeside/north wales
    124
    As above through the wheel arch liner just turn wheel on full lock and remove the two Torx screws that hold the liners together and bend it back for access to the back of the light Much easier that way
    My red sportback pics
    WANTED - 10mm hubcentric wheel spacers
    Mar 2010
    Slovakia
    okk thanks much guys
    meanwhile, i tried the arch liner approach but was just too pussy to use force and bend it, i thought that you need to take the wheel off and put the whole arch liner away.. nevermind ill do it tmrw...hopefully thx again !
    Chris71's Avatar
    May 2011
    Deeside/north wales
    124
    okk thanks much guys meanwhile, i tried the arch liner approach but was just too pussy to use force and bend it, i thought that you need to take the wheel off and put the whole arch liner away.. nevermind ill do it tmrw...hopefully thx again !
    If you r still struggling to fit with wheel on you can remove the wheel and liner completely and then you can get your head in there and have a good look,it's easier but more long winded
  1. Headlight Bulb Change on A4 2006 (B7)
    By comc in forum General Technical / How To
    Last Post: 6th February 2010, 21:15
  2. Audi A4 avant airbag light after headlight bulb change!
    By fabtdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th January 2010, 07:14
  3. 2006 A6 Headlight bulb change!
    By walshyuk in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th January 2010, 17:27
  4. Halogen Bulb for DRLs
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th September 2007, 12:39
  5. headlight bulb change info reqired asap
    By jackster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2005, 09:40
