Sky InsuranceEM Tuning
Thread: hvac removal
    dav150n's Avatar
    Sep 2011
    north east
    43
    hvac removal
    is there a removal guide anywhere for this??
    tried searching but going to be late for work ha.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Pull out your radio if double din, remove panel strip around buttons, hazard, ESP etc, then you should be able to pull out your hvac. Is single din radio, then just remove radio and follow rest if procedure.
    Hope this helps mate.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  1. Error HVAC module - 01301
    By davej_anderson in forum VCDS (formerly VAG-COM) forum
    Last Post: 7th February 2014, 17:18
  2. VCDS Problems communicating with 08 Auto HVAC
    By HerefordQuattro in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th January 2011, 23:40
  3. Customizing the HVAC
    By cochinada in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2008, 23:08
  4. Auto HVAC
    By s3ollie in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2007, 19:27
