EM TuningJMB Retrofits
    tdi-man's Avatar
    Jul 2009
    1,609
    oil leak back of engine
    hi just noticed i got an oil leak from the back of the engine
    any body got any ideas ?
    its at garage tomo so will have look anyway
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,815
    Turbo is located at the back but without seeing the engine it will be very hard to internet diagnose the problem.
    tdi-man's Avatar
    Jul 2009
    1,609
    Looks higher up than turbo so just getting rocker gasket
    As
    In garage tomo for hybrid fitting
  1. Common place for oil to leak on a 2.0tdi engine?
    By fozworth in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd September 2010, 22:22
  2. Engine replacement due to oil leak
    By freestuffinnit in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th August 2009, 13:47
  3. Water Leak From Front of Engine (2.0 Tdi)
    By Resin Rocket in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 12th May 2009, 13:13
  4. Leak in Back Footwell ( Pollen Filter)
    By Rev-head in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th April 2006, 21:42
  5. Leak in the back passenger well??
    Last Post: 29th March 2006, 19:17
