Sky InsuranceVolks Autos
Results 1 to 30 of 30
Thread: MFSW - Help
    Jul 2011
    Sampford Peverell
    131
    Question MFSW - Help
    Hi.. am trying to buy a MFSW for my 06 SB .. if i buy one with the same style airbag as mine would this mean i can fit it with no extra parts needed? I know it will need coding but i need to know if there are more parts needed.
    wez3570's Avatar
    Jan 2011
    711
    Honestly mate, that question has been answered so many times.
    Just use the search button and you'll see what I mean.
    I was in the same position as you, looking to add MFSW, after a quick read though I realised it's not exactly straight forward.
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    V Maxx plus coilovers
    Speedlines- anthricite
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    For Sale Genuine Audi phone cradle (iPhone 4S/4)
    Fossie
    Rhubarb Triangle
    3,961
    It is much appreciated by all when a person asking a question has at least attempted to find the answer themselves. As Wez says this has been answered dozens of times before ( at least 10 times by me ! ).
    Basically you need to have the correct steering module which has the suffix 'F'. To find this out you need to VCDS scan the car. I have a 2006 SB and it did not have the correct module. In addition there are two types of airbag fittings for reasons best known only to Audi and you need to get the right mfsw for your airbag.
    I have both types of wheel available but they will be of no use without the correct steering module. They are like 'rocking horse s**t' on ebay and cost about £150 - £180 from Audi.
    That's 11 times !!!
    wez3570's Avatar
    Jan 2011
    711
    Maybe there should be a MFSW sticky?
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by wez3570 View Post
    Good idea but needs two things. One is a Moderator or Administrator to accept the idea and two is someone to write it !!!!!!
    Bet someone would post a thread because their exact question hadn't been answered clearly enough !!!
    wez3570's Avatar
    Jan 2011
    711
    Very true!
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    Jul 2011
    Sampford Peverell
    131
    Hi, thanks for the replies.. i did do a search but found a lot of the information confusing so i thought i would try and ask.. sorry guys.
    Your help is much appreciated.
    Jul 2011
    Sampford Peverell
    131
    I have just managed to pick up a steering ecu with a part number 8P0 953 549F
    Is that the right one for MFSW?
    wez3570's Avatar
    Jan 2011
    711
    Quote Originally Posted by Dazza0685 View Post
    yep
    You may also need a MFSW capable slip ring
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    Jul 2011
    Sampford Peverell
    131
    Ok cool.. does anyone know any parts numbers for the slip ring?
    wez3570's Avatar
    Jan 2011
    711
    1K0 959 653 D
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    Jul 2011
    Sampford Peverell
    131
    Brilliant thanks WEZ3570
    Aug 2011
    242
    I have to say a big thanks to MIke Foster (among others) who helped me out in finding the appropriate wheel from the usual source.
    My issue was wanting to reuse the airbag. The rest of the info was standard, module/slip ring etc, but knowing if the airbag would fit my new wheel was the main problem.
    I haven' received my wheel yet but from taking my current airbag off, I have been able to determine exactly what I needed the new one to look like and am very confident it's going to work.
    Interestingly, mine is a 2005 car, and yet the wheel/airbag combination is consistent with the design that many people tell me audi changed to in 2009.
    In short, something wasn't quite right there!
    Jul 2011
    Sampford Peverell
    131
    Very strange.. i also would like to stay with my current airbag if possible.. Do you need any other cables or are the ones in place good enough?
    Shane.'s Avatar
    509
    There should be a retrofit sticky really. As said usual problems are steering ECU, slipring, cables for inside steering wheel. Make sure the airbag is for A3, the A4 wheel looks the same but is slightly different inside. I have a slipring for sale which I bought for mine then realized it wasn't needed.
    STUFF FOR SALE: DLS R6 Midbass drivers, MFSW 3 spoke and Pioneer P88RS II
    STUFF FOR SWAPS:
    3 door A3 8P custom doorbuilds
    please contact for more info
    Fossie
    Rhubarb Triangle
    3,961
    You need the right wheel to fit your airbag and a new airbag wiring harness with the extra plug for the multi-function bit.
    Can't remember the harness number but it is suffix 'Q'
    Edit :- part number is 8P0 971 589 Q
    Shane.'s Avatar
    509
    Harness part number: 8P0 971 589 Q (dual stage airbag with mfsw control)
    STUFF FOR SWAPS:
    Jul 2011
    Sampford Peverell
    131
    This is priceless info, thanks guys.. one more question tho. Where is the best place to get the cable i need? Audi ? or is there somewhere cheaper?
    Fossie
    Rhubarb Triangle
    3,961
    Audi - approx £25. It's not worth trying to find one elsewhere
    Jul 2011
    Sampford Peverell
    131
    Thats ok then not too much.. i have just had a look and i already have the correct slip ring. Is it likely the steering ecu could be the correct one if i have the right slip ring? I dont have VCDS yet so cannot find out.
    wez3570's Avatar
    Jan 2011
    711
    Is your car DSG or manual?
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    Jul 2011
    Sampford Peverell
    131
    Manual..
    Jul 2011
    Sampford Peverell
    131
    Also i caused myself a bit of a problem.. while removing my airbag and wheel to see what systems i already had i knocked the top off the slip ring and the wires came out.. i put them back the only way i could see how.. when i turned the ignition back on after reassembling the esp light and steering light came on, i took it for a very short drive and they went off.
    Could i have damaged it?
    Also the airbag light is now on.. !
    wish i hadnt bothered now.. lol
    Shane.'s Avatar
    509
    That's quite common really, had same thing happen to me and few others I know. Aslong as it goes off after a short drive it's fine. As for where to get the part either audi or TPS if you have access to an account with them
    STUFF FOR SWAPS:
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    Hi fella, yeah it is common for the ESP light and steering wheel light to come on. This always happens when you remove the wheel and airbag, and should always go off after driving a few meters. Nothing to worry about mate. As for your airbag light staying on, this is because most likely you disconnected the airbag and probably started your engine, therefor reading as a fault! Easily cleared with vcds. But in future mate, it is heavily advised that BEFORE you disconnect the airbag, that you make sure to disconnect the car battery, as failure to do this, could and has happened before, cause your airbag to go off, causing you injury and a good part of your well earned cash to buy a new airbag.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Jul 2011
    Sampford Peverell
    131
    Thanks for the advice but i did disconnect the battery before taking the airbag off as im fairly used to working on cars.
    Thats why i found it weird that the airbag light is now on hence the battery being disconnected the whole time the airbag was removed. Makes me worry that i may have caused an issue..
  28. #27
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    Ok sorry Dazza. Uummm strange, did by any chance when you put the steering wheel back on, did you connect the battery back and turn on the ignition before you reconnected the airbag back? I'm sure you did fella. Other than this not quite sure what could happened, maybe something to do with Shen you knocked the slip ring. Best bet is to try and get someone to connect to there vcds. Try to clear fault, and if it doesn't then you may well have a problem.
    If your anywhere near London, I'll be more than happy to check for you mate.
  29. #28
    Jul 2011
    Sampford Peverell
    131
    No unfortunately the battery was disconnected until i put everything back together thats why im concerned, Hopefully it will be getting read tomorrow so that should shed some light.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    Keep us posted mate, it will be interesting to find out what it is.
  31. #30
    Shane.'s Avatar
    509
    I have taken my airbag out probably atleast 8 or 9 times now, not once with the battery disconnected and the warning light has only happened once of of all of these times, it's really nothing to worry about. On vagcom it comes up as one of the sensors not reading (steering column allignment iirc)
    STUFF FOR SWAPS:
  1. will this fit (MFSW)
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th April 2010, 14:37
  2. Non-MFSW to MFSW - 3-spoke wheel in B7 S4
    By pdt in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th January 2010, 15:31
  3. MFSW
    By karl88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2009, 10:46
  4. Which MFSW?
    By 3.2 Ju in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2009, 10:50
  5. MFSW ?????
    By 1wheelonly in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2009, 20:10
