Volks AutosMonster Motorsport
Results 1 to 9 of 9
    Sep 2010
    Lincoln and Halifax
    143
    Boost Gauge help please...
    I would like to fit a digital boost gauge to my REVO'd 2.0 TDI Sport. I have fitted boost gauges to previous cars but occasionally I have cheated and run the silicon hose through the door and wing. I'd like to do this one properly.
    This being my first diesel too, I don't know where I should be connecting the silicon hose and then just getting the hose through the bulkhead etc.
    Thanks all.
    Sep 2010
    Lincoln and Halifax
    143
    Any help folks please?
    A3 TDI 140 - REVO Software, Cupra R Splitter, Lamin-X Yellow Fogs, Spax 45mm Springs, 18x8 RS4 Reps In Gloss Black, De-Wipered At Rear
    JamesS4cab's Avatar
    Mar 2008
    1,091
    I fitted mine to my S3 a few months back.
    Take a feed for the silicone pipe off of the DV and then run it through the bulkhead on the drivers side. There is a gromet behind the wiper motor that leads into the car up behind the fuse box. I used a coat hanger todrag it through.
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,456
    Hi james could i also see your deck money guide to fitting a boost gauge,,cheers
    Sep 2010
    Lincoln and Halifax
    143
    Quote Originally Posted by JamesS4cab View Post
    The diesel doesn't have DV does it? Cheers
    Aug 2008
    408
    The feed is taken from the intake pipe at the rear of the
    Engine, its large and made of plastic, you cant miss it
    Cal
    Sep 2010
    Lincoln and Halifax
    143
    Quote Originally Posted by bluequattro View Post
    Cal
    Do I tap into it then or is there some piping coming off it that I can t-piece from?
    Aug 2008
    408
    Just tap into it m8
    Sep 2010
    Lincoln and Halifax
    143
    Cheers blue
  1. Boost leak, Weak Actuator or boost gauge?
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 13:51
  2. Replies: 0
    Last Post: 17th January 2011, 21:00
  3. Boost gauge only reads negative boost?
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2009, 21:45
  4. boost gauge
    By kenny_boon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th October 2006, 03:49
  5. Boost Gauge
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th October 2004, 23:10
