Boost Gauge help please...
MarkTweedley
Lincoln and Halifax
I would like to fit a digital boost gauge to my REVO'd 2.0 TDI Sport. I have fitted boost gauges to previous cars but occasionally I have cheated and run the silicon hose through the door and wing. I'd like to do this one properly.
This being my first diesel too, I don't know where I should be connecting the silicon hose and then just getting the hose through the bulkhead etc.
Thanks all.
I fitted mine to my S3 a few months back.
Take a feed for the silicone pipe off of the DV and then run it through the bulkhead on the drivers side. There is a gromet behind the wiper motor that leads into the car up behind the fuse box. I used a coat hanger todrag it through.
Hi james could i also see your deck money guide to fitting a boost gauge,,cheers
The diesel doesn't have DV does it? Cheers
The feed is taken from the intake pipe at the rear of the
Engine, its large and made of plastic, you cant miss it
Cal
2K
445
538
15
3K
684
