Chris NottVolks Autos
Results 1 to 20 of 20
    Sep 2011
    Coventry, West Midlands
    23
    ISO to Quadlock adaptor
    Hi.. hoping someone can help!.
    I've bought a Dynavin headunit (dont shoot me!) but to complete the installation i need an adaptor of some sort which will convert my stock ISO cables into a quadlock connector so i can plug-in the dynavin. Anyone know where i can get one from?...
    Cheers!
    Fossie
    Rhubarb Triangle
    3,961
    A quick look on ebay mate and I found this :- Audi ISO harness wiring adapter lead CT20AU01 quadlock | eBay
    Any car audio place should fix you up !!
    You don't give any info about your car but presumably you already have a double din head unit (Symphony/concert) otherwise lots of other bits will be required !
    Sep 2011
    23
    ..what im after is something that will convert the audi iso cables/connectors into a male quadlock... its the opposite of the ebay thing, as the connection on the Dynavin is a female quadlock one. (hope this makes sense)
    oh car is a 56 plate sportback with symphony 2 cd changer unit and has a antenna on roof(if that helps)
    Fossie
    Rhubarb Triangle
    3,961
    Should be ok then - bear in mind it's worth checking these things before you buy in future !
    Jun 2010
    Milk n Beans (Milton Keynes)
    109
    On the same subject, I recently bought the wrong Dension gateway 100 (gw16ai2) for my S3 8L concert radio.
    Andymac said that my head unit is an ISO connection and this flavour Dension is for quad lock. So can I buy an adapter that connects to my iso that leaves a quad lock connection for my Dension to fit?
    (I know most of you wanna say "just sell the one you have and buy the right one" but I got this one free...)
    Jan 2012
    Hi I have also bought a dynavin does any one know if there is iso conector converters ? Thanks phil
    Nov 2012
    78
    Did anyone ever find a place that sells iso to quadlock adapters? just upgraded to symphony 2+ and i need the cable
    Fossie
    Rhubarb Triangle
    3,961
    Here's a few to choose from :- Audi A3 iso quadlock adapter | eBay
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Nov 2012
    78
    Hi mike thank you for the reply.
    Will this would as i have a 2005 a3 with symphony 2 (tape player aswell) to symphony 2+ 2007 onwards.
    I currently have iso connection but the new unit is quadlock.
    Fossie
    Rhubarb Triangle
    3,961
    This one should have all the connectors for converting your ISO leads to Quadlock.
    Check the coloured plugs behind your headunit and you should find that the coloured sockets will match.
    AUDI A3 A4 A6 TT ALLROAD RNS-E P&P Adapter QUADLOCK - ISO FAKRA CHORUS CONCERT | eBay
    Nov 2012
    78
    i dont think that will fit?
    i need this dont i but from an english website
    BNS 5.0 / Concert 2+ / Symphony 2+ Plug&Play Adapter - Audi A3 8P / A4 8E
    it needs to fit this head unit
    https://www.google.co.uk/search?hl=e...w=1440&bih=799
    I really appreciate your help
    Fossie
    Rhubarb Triangle
    3,961
    I'm not convinced there is any difference !
    Two black, one brown and one orange connector into quadlock. Take off your headunit and check the plug colours.
    Nov 2012
    78
    i will take a photo of the back of old one for you but the quadlock end of the link i sent looks like it would fit exactly into my new one
    Nov 2012
    78
    Pictures attached of current system(in black) and picture of system i hope to upgrade to(in white)
    Any help would be hugely appreciated.
    Nov 2012
    78
    Is this what i need?
    Fossie
    Rhubarb Triangle
    3,961
    The plugs that currently go into the black (existing) unit should be coloured orange, brown and two black.
    They will go into the corresponding sockets in this adapter :- AUDI A3 A4 A6 TT ALLROAD RNS-E P&P Adapter QUADLOCK - ISO FAKRA CHORUS CONCERT | eBay
    and then the quadlock (square) connector goes into the white one. By the way, that picture of the white one shows and RSNe navigation unit !
    You don't need to worry about which plug is which because they will only go into the socket designed for them and will only go in one way round.
    Nov 2012
    78
    thank you Mike.
    I will order this and hope it works.
    Nov 2012
    78
    All ordered and fit fine but the player makes whiring noises but wont power on!
    any ideas?
    thank you
    Nov 2012
    78
    If anyone knows the answer to this then it would be worth making a sticky as these threads keep popping up and this one alone has nearly 2k views
    MacrosTheBlack's Avatar
    Mar 2008
    Kent
    204
    Hey Chale, saw this thread on another forum and looks like it could help solve the problem for you
    UPgrade from symphony II to II+ ISO to Quadlock help | VAGOC.co.uk
    Sold:Audi S3 (2008 8P2 with upgrades by NHN)
    Phantom Black
    , Bucket Seats, Sunroof, Parking Sensors, FBMFSW, Armrest Phone Prep, Privacy Glass, ILP, FTW, BOSE, RNSE MkII SDS & AMI, Cruise Control, MY11 Folding/Dimming Mirrors, MY11 Rear Lights, Auto Lights/Wipers
  1. Which Quadlock Adaptor?
    By fgaffney in forum In-Car Entertainment
    Last Post: 7th August 2010, 06:53
  2. ISO to Quadlock Adaptors
    By darkside in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2010, 18:51
  3. Quadlock connector
    By GeoffT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2008, 15:03
  4. Replacing ISO with Quadlock
    By terrymcg in forum In-Car Entertainment
    Last Post: 4th March 2007, 19:49
Tags for this Thread
