Badger5JMB Retrofits
Results 1 to 8 of 8
    Jan 2005
    London
    70
    Suspension Kit vs. Springs+Dampers
    As above, I want to impove my car's road hugging abilities, but I am on a tight budget.
    Can anyone tell me the pros and cons of going for a whole suspension kit (not coilovers as these are way out of budget) over a respected set-up like H&R springs + Bilstein dampers - quality, reliability, price... [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Like most here, I want to get the biggest improvements possible for as little money as possible!
    cheers in advance
    Feb 2004
    Clearfield, PA
    892
    Re: Suspension Kit vs. Springs+Dampers
    FK do really good cheap Kits
    Jan 2005
    London
    70
    richy - how much are the fk kits?
    I am after a very decent ride, and am strongly considering the tried and tested H&R spring/Bilstein damper setup. I am just wondering if I can get a better performing 'integrated' kit for less?
    However I dont want to get into ARBs (still not sure what they are) and bushes and the like as my budget stops before Ess_Three's!
    Feb 2004
    Clearfield, PA
    892
    well the height and damper adjustable coilovers are 500/600 depending where u get them...
    so the normal kits are going to be well below that...
    Jan 2005
    London
    70
    really? the coilover kits I've seen have been around the 1000 mark.
    I am looking for a quality brand I can trust, and so have probably been looking at some expensive sites as well!
    which manufacturer does a 600 set?
    either way, i have no use or time for an adjustable set up in my TDi - that will wait for my next, and hopefully fast, car!
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    i was looking at koni shocks, specials & sport shocks adjustable damping but they about the 500 quid mark
    special offer up to 30% firmness adjustment and sport 25% and up
    koni's are definently tried and tested!
    Feb 2004
    Clearfield, PA
    892
    the FK are the Koni
    Jan 2005
    London
    70
    ok... i feel like a complete idiot now... i dont know how i failed to make the link of ARB = Anti Roll Bar!!!
    I had just springs on my golf mk4 with standard shocks. and turn in improved considerably as well as body roll, but the ride suffered badly. this time i want to change the shocks as well as and try to understand more about the car handling.
    I heard the Konis can be too stiff but i guess thats down to settings. Basically my budget is about 500, stretchable slightly if the gains are worthwhile of course! #
    What would be recommended? Also with the H&R/Bilstein setup, which ones are the dampers to have as they have a few models.
