Volks AutosMonster Motorsport
    Feb 2011
    535
    Will my rear tyres fail an MOT?
    The inner edge of both rear tyres (about 1" in width) is pretty much bald although the rest of the tyre tread is very good. This is the same on both wheels.
    1 - Will this mean a fail on next week's MOT?
    2 - How has this happened as I don't fancy forking out for new tyres only for the same to happen again.
    WANTED: S3 Side Skirts (3DR)
    A3 S Line DSG TDi 140 (56) | Lava Grey | Groove & Drilled Discs | Green Stuff Pads | Eibach Sportline Springs | Eibach Spacers | Full heated leather | RNS-E 2010 MK2 | Rear Parking Sensors | Interior Light Pack | Heated Mirrors
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    i would say you would fail. anything lower that 1.6mm i beleve ( could be wrong)
    just get the tyres now and save youself £50 on another test.
    it may be camber angle or alighnment. it it lowered ?
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade, fully machine corrected!
    Oct 2010
    Bedfordshire
    58
    The rule is there must be a minimum of 1.6mm across 75% of the tread width. If they are 225 tyres and you have only lost 1 inch then you will be alright - provided there is no damage to the carcass of the tyre. You will probably get an advisory though.
    The inner edge wearing on tyres is usually a result of excessive 'toe-out'. ie the leading edges of the wheels are further apart than the trailing edges. On the rears though it can be a result of suspension geometry where the tyres run on their inside edge when the suspension is compresssed. Often they run extra 'Toe-in' to counteract this. Other issues can be wheel bearings but it is unlikely they would both go at once.
    Personally i would find a good garage who can do a full four wheel geometry check (about £50-£100) which should diagnose the problem.
    Matt.
    A3 SB BE 170 TDI Quattro- Phantom Black
    If women can multi-task why can't they approach a roundabout and look right at the same time?
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Jameze's Avatar
    James
    Jul 2011
    Leeds
    525
    Quote Originally Posted by MattBE View Post
    This.
    I remember having to learn that statement for my driving test.
    My front offside tyre was bald around the edge a couple of years back when I was due an MOT and wasn't sure if I'd fail or not, I only got an advisory though. I changed my two fronts shortly after just to be on the safe side. I wasn't sure why it happened though so just assumed I was driving too fast around roundabouts... in my 1.4 Clio... - I preferred that logic
    I can't pretend I know about the second part about "toe-in" though, you could fit my technical knowledge of cars on the back of a stamp
  1. Quattro rear tyres wearing on outside?
    By neilA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st August 2011, 19:50
  2. rear wheel bearing = mot fail?
    By quattro1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2011, 19:13
  3. Tyres : 225 45 17 front 235 45 17 rear ?
    By alictait in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd January 2011, 07:35
  4. Best two tyres on the front or rear??
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2010, 06:59
  5. MOT fail, 4 days to fix. Anyone have a spare rear spring?
    By sportstractor in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2010, 19:22
