Volks AutosEM Tuning
    Jun 2011
    11
    What do these fault codes mean ?
    Wednesday,14,September,2011,18:29:07:43475
    VCDS Version: Release 10.6.4 (x64)
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Control Module Part Number: 8P0 907 279 P HW: 8P0 907 279 P
    Component and/or Version: Bordnetz-SG H54 2903
    Software Coding: 13AC2F81C0141380EF00001C00800000002A4E056406400300 1800000000
    Work Shop Code: WSC 06314 000 08192
    Additional Info: 8P1955119F Wischer AU350 H10 0040
    VCID: 4A91756C5C2F
    Fault Codes have been Erased
    2 Faults Found:
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 171
    Mileage: 74882 km
    Time Indication: 0
    Date: 2011.09.13
    Time: 18:28:00
    Freeze Frame:
    ON
    Voltage: 14.00 V
    OFF
    ON
    OFF
    OFF
    OFF
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 171
    Mileage: 74882 km
    Time Indication: 0
    Date: 2011.09.13
    Time: 18:28:00
    Freeze Frame:
    ON
    Voltage: 14.00 V
    OFF
    ON
    OFF
    OFF
    OFF
    I cant figure out what it means ? Voltage too high or too low ?
    This happend after a bi-xenon install over halogen. On a 2009 Audi A3 S-Line.
    I cant figure out why my LEDS dont light up...
    Jun 2011
    11
    I plugged the Kufatec harness wire on the ECM on plug A pin 7 and plug D pin 10. Those are supposed to be the ' SIDELIGHTS' pins.
    The LED DRL dont light up, so i guess there is no power going trought the wire...
    Lewis583's Avatar
    Mar 2010
    870
    Have you coded the bi-xenons to the car and enabled DRLs?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jun 2011
    11
    Quote Originally Posted by Lewis583 View Post
    09-Central Elextronix
    Coding -> Function 07
    Byte 00 Bit 1: Xenon Headlights installed
    Byte 03 Bit 4: Xenon-Shutter installed (Bi-Xenon) Can't code this one, tell me 'Error 31'
    Byte 17 Bit 1: Deactivation of Additional High Beam with Bi-Xenon
    Byte 21 Bit 26: (26= BI-Xenon with DLR LED) change byte 21 from 25 to 26 This is a drop down menu, i chose option 6, Bi-xenon with LED DRL
    I did this.
    Jun 2011
    11
    My headlight switch inside the cabin got a 'DRL' position. Is there a way to wire it directly to some power source ?
    27,094
    You need to wire it in exactly as per elsawin details, that way it will work.
  1. My fault codes. What do they mean?
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2008, 21:03
  2. Fault codes.
    By nickelvery in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2007, 12:37
  3. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
  4. fault codes A3 TDI
    By Evstdi in forum Diesel forum
    Last Post: 14th February 2006, 11:35
  5. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
