AH FabricationsVolks Autos
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    2.0 TDI OVERFILLED OIL!
    Hi all,
    Basically in light of my recent limp mode experiences I decided to have a look round the car to look for any boost leaks... only to my horror to find the oil being way past the max mark on the dipstick. So i'm assuming its been like this since it's last service which was 7000 miles ago (Only bought the car 2000 miles ago). So my question is could this be the reason my car's been throwing an overboost code? And what possible damage could this have done?
    Regards
    Zo
    55' BMW 330Cd M Sport
    The ones that have been left behind:
    • 2004 VW Golf R32
    • 2004 Audi A3 2.0 TDi Sport
    • 2000 BMW 318i M Sport
    Private plate for sale: Y 7RYY
    tdi-man's Avatar
    Jul 2009
    1,589
    do not drive DRAIN OIL to correct level straight away.
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    Did you take the oil level when the engine was hot?
    Also when you say it was way past the mark how much over was it?
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    Might sound like a stupid question but do you check the oil when cold? or after its been started and sat for a while?
    • 2004 VW Golf R32
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    best time to check oil level is when cars been sat overnight on a level surface......!!! or after its been driven,after about an hour....again make sure cars on level ground.
    Quote Originally Posted by Zo View Post
    Full leather/19"wheels/cruise/
    Sportback owner
    Apr 2007
    France
    466
    Zo, be careful to correctly interpret the actual level of oil. The 2.0L TDI dipstick is a disaster design, and gets smeared with oil every time you pull it out. You need to try several times, cleaning the dipstick end each time, until you get a good reading. I accidentally overfilled once, and then had to poke a thin plastic tube down the dipstick hole, and suck out the oil. Well that is better than having to take off the undertray and then having oil all up my arm. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
  1. Overfilled Oil...
    By JD56 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2011, 16:27
  2. Overfilled Oil - Idiot!
    By Louis Cronin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st October 2010, 20:16
  3. Overfilled oil
    By S3Matt in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2009, 22:09
