Chris NottSky Insurance
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Removing clocks from A3 tdi 2.0 sport
    Chaps
    Is it easy enough to remove the clocks/instrument cluster?
    How to do it?
    ...to replace a couple of bulbs..
    Khufu's Avatar
    West coast of Scotland
    5,693
    I'm sure there are no replacable bulbs unless you plan to solder a new one in.
    To removed it, release the steering adjustment latch & pull the steering wheel towards you and down & lock it
    The trim under the clocks pulls out towards you & will reveal two 10mm bolts. Remove these and slide the clocks out. As you turn them to remove it you will see a multiplug on the back. It is held in with a catch that has to be rotated out of the way. As you rotate it, the multiplug should come out at the same time.
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Great - cheers mate
    27,113
    LED afaik.
  1. A3 T Sport - Removing seat covering/lining?
    By Stanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2011, 14:21
  2. Clocks
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2011, 00:29
  3. Will b7 clocks fit a b6?
    By A4 nut in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2010, 20:27
  4. Removing front grille without removing bumper?
    By maars in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2008, 11:14
  5. removing clocks?
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd February 2007, 09:20
