Results 1 to 8 of 8
    Mar 2011
    93
    S3 Suspension noise
    Hey,
    Just picked up an S3 with about 600 miles on it a couple of weeks ago - 2 tiny things I've picked up on that worry me slightly - over speed bumps etc theres a noise i can hear off the front suspension - almost like theres something a bit bigger than a leaf stuck in it brushing up against rough bodywork inside the wheel well.
    Also, when turning either way, I can feel the slightest vibration through the footrest - nothing when going straight, and like I say it is only just perceivable.
    Should I be worried about either of these?
    Cheers,
    Ben
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,773
    Like a "squish" noise going over ramps - this is normal.
    Don't know what the second issue could be - get under the car and check for wear but if it has warrenty then get it into Audi
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Check your tyres, sounds like one could be a bit out of shape. I had that vibration when not straight after i hit a pot hole and when i jacked the car up and span the wheels i had bent the reinforcing wire in the tyre. Check the pressures too
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I dont know how old your car is ben, but worn top mounts on the front suspension legs can make those noises...
    Mar 2011
    93
    Brand new effectively - Its very subtle though - I can only hear it with windows down and radio off!
    bagey's Avatar
    aud you do !
    Newcastle
    198
    is it just one side ? if so try changing wheels round as im having the same kind of problem and it seems to be an alloy/ tyre issue as the noise has switched sides now
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,148
    The brushing noise when going over bumps I don't think is "normal".
    I know exactly the noise you are talking about... sort of a sandpaper scrape noise?
    My first A3 did it, but my second one didn't.
    I don't know what the cause was though because I sold the car, but it never got any worse, just stayed the same.
    Sorry, not very helpful, but just to let you know it's not a feature of all 8Ps.
    Mar 2011
    93
    Yeah that sounds like it - it's not a nasty noise as such, just seems like it probably shouldn't be there.
    I've tried bouncing on both sides at the front and can't recreate it when static - is there anything which could possibly rub on the wheels to check?
  1. Suspension noise
    By ROBS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2007, 20:12
  2. Suspension noise ??
    By sykopat in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd June 2005, 15:28
  3. suspension noise
    By MickA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2005, 11:59
  4. please help. is this noise from suspension ?????
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2003, 21:19
