Sky InsuranceVolks Autos
    MTW
    MTW's Avatar
    Feb 2011
    212
    rather big problem.....
    ok, wondering if anyone could shed any light, lately ive been noticing the car making much more of a wooshing sound at low revs, i suspect a boost leak....but when i floor it, the wooshing suddenly stops at about 2k rpm and the car livens up again, but i noticed today now in 3rd gear, the car bogs down quite badly and when i try to accelerate the car bogs down then suddenly takes off leaving a big black cloud of smoke behind it, is this just a boost leak? or something worse? if so any common problem areas it could be?
    thanks.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Is it a TDI?
    Sounds like an EGR Valve failure. Take it out, located beside throttle body, clean it, replace seal and see if that cures it. If not, replace the EGR or even blank it off if you can??
    MTW
    MTW's Avatar
    Feb 2011
    212
    hi sorry yea its a 2.0 tdi, ok mate cheers ill give that a try
  1. problem after problem... juddering...
    By ian 06 A3 2.0 tdi s line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2011, 21:09
  2. Update on problem and another problem!!!
    By evilbane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st December 2010, 00:10
  3. Replies: 1
    Last Post: 21st August 2010, 19:41
  4. brake binding problem / abs light problem
    By brendan in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2008, 20:24
  5. A4 Tdi, engine problem AND steering problem! PLEASE help!!
    By mattsavage in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2007, 16:02
