Volks AutosChris Nott
Results 1 to 9 of 9
    Mar 2011
    Wolverhampton
    125
    Quick ABS coding question...
    HI guys im coding in my new abs ecu and im looking at the rosstech code generator thingy and all i cannot understand is where it says frontbrakes (sensor cluster old or sensor cluster new)
    My wheels are 18" but i can only see where it says front brakes 15 16 or 17?
    If somebody could let me know how i figure this little game out it would be MUCH appreciated as iv just spent 600 quid on an abs ecu and dont want it to fubar! Thankyou fellas
    2006 A3 2.0 TDI Quattro S-Line l Team Heko Wind Deflectors l Celtic Tuning Remap l Rear De-Wiper l Pipercross Panel Filter l
    After a Passenger Xenon Headlight for A3 8P. No ballasts required. PM ME!!
    Mar 2011
    Wolverhampton
    125
    Please help somebody, I havent a clue.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,333
    Hi, maybe private message user NHN or Khufu, they only ones i know who may be able to help you out. Im sure they will point you in the right direction if they dont know.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Mine is set to 17" despite 18" wheels. I cant remember what else needs done offhand but IIRC, you need to do a brake pressure check & calibrate the longitudinal & lateral senors after its coded. What ever you do, dont select the ESP test - its a bugger to complete all the tasks to get the ESP light to go out LOL
    Mar 2011
    Wolverhampton
    125
    Alright chap thanks for your help! Will have ago and let you know. Hopefully I will be able to do it without vcds :/
    Khufu's Avatar
    5,693
    You can't, it's needed 100%
    Mar 2011
    Wolverhampton
    125
    Sh*t.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,333
    Get in touch with Nigel (NHN). He supplies the cables, he has good reputation, ask anyone on here, and you will get good reliable service.
    Mar 2011
    Wolverhampton
    125
    Right, ive in fitted new abs module and ive tried to use my own scanner to code it in but for some reason it wont connect with any abs related component. My original ABS unit was 1K0907379R and the one they have gven me is 1K0907379AB.
    On my invoice it says superceeded but i cant understand why it wont connect. I was thinking of taking it to audi specialist and see if they can communicate with it:/
  1. Quick question quick reply needed !!
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd September 2011, 10:51
  2. CE module coding question
    By Khufu in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th July 2011, 12:19
  3. QUICK QUESTION...QUICK ANSWER NEEDED!
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2009, 16:33
  4. Quick question that needs a quick answer!
    By ScottSummerhayes in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2009, 16:12
  5. RNS-E VAG coding question
    By jvbates in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st April 2007, 20:58
