Volks AutosBadger5
Page 1 of 2 12 LastLast
Results 1 to 40 of 60
Like Tree1Likes
Thread: A3 Face lift Headlight problems. HELP
    Jun 2011
    63
    Exclamation A3 Face lift Headlight problems. HELP
    Hey guys, recently went from a 8p 06 front to a newer shape everything went ok. Now i keep getting a fault code saying that i got no
    headlights on the computer. How do i re-code them anyone got any links or ADVICE
    also my passenger airbag is off can i turn it back on using a vagcom?
    Thank YOU
    27,075
    Have you connected the headlights up properly & coded accordingly?
    Aug 2009
    Costa del Cardiff
    535
    No lol
    Jun 2011
    63
    CORRECTION FROM THE ABOVE POST! THE PARKING LIGHTS DONT WORK!!
    Yes everything else works fine headlights, high beam, fog lights and indicators! its just the parking lights don't work. Had a vag-com guy come have a look at it today he couldnt code it, he said i need a resistance pack because the comp thinks the lights are out due to a difference in voltage. is he right? and what does that mean exactly?
    Jun 2011
    63
    Quote Originally Posted by JoeD View Post
    No lol
    They were connected properly., i can upload pics if it helps?
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    The car knows what the resistance should be across the side light bulb. It is saying the resistance is wrong so you either havnt got a bulb in/have the wrong bulb in/ or have an LED in instead of a bulb. Basically the computer has cut the power to the bulb because it thinks its blown due to getting the wrong resistance signal back from it.
    Thats a bit simplified but it should give you a clue
    Jun 2011
    63
    Unhappy
    Quote Originally Posted by paddy View Post
    Yeah thanx that helps a little, how do i fix it? what are my options?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    What bulb do you have in there at the moment? As paddy said the parking light is the sidelights/DRLs on the facelift so make sure that is using the correct bulb.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Jun 2011
    63
    Quote Originally Posted by itwasntme187 View Post
    Im using the ones that came with it, i didnt change anything just insalled the headlights everything else works fine. They look like this.
    LINK: File:2009 Audi A3 (8PA) 1.9 TDIe 5-door Sportback 01.jpg - Wikipedia, the free encyclopedia
    Jun 2011
    63
    The headlight came with all the bulbs so i just installed it, didnt change anything else.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    if the bulbs are correct and standard and i am guessing you dont have the bi-xenon with LED DRL then i would say that the DRLs are either not wired in correctly (that they are plugged into the wrong plug/pin) or not coded in correctly. now as the 'coding guy confirms it is not a coding issue then i would double check the wiring... i will try and have a look a little later on ELSA to see where its meant to be wired.
    bowdizle likes this.
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Jun 2011
    63
    They are standard not bi-xenon, the DRL dont even turn on i dont know if they even should as you can see from the link should they turn on as they are next to the indicators. He couldnt find anything in regards parking lights on the vag-com. Let me know, Thank you so much.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    the DRLs should switch on when they are set to be on the light switch... the 'Parking light' fault indicates something is wrong with the DRL bulbs or connection. Have you got the actual error code from the 'coding guy'?
    I dont know the coding for the facelift halogen lights off the top of my head but im sure someone here that has them can advise.
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Silly question but you do have a DRL or auto position on your light switch ????
    Khufu's Avatar
    West coast of Scotland
    5,693
    Would a 2006 CE module regardless of level be able to be coded for LED headlights?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    im pretty sure if you mean the LED DRLs on the facelift version then you need the F/K rev as they are also Bi-xenon!
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,434
    If any you guys looking for a ce module 8p0 970 279k there is one posted in classified section for sale. post no 52. its not marked as sold so may be worth a look.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I dont think they are LED DRL's, mine go across the top of the light..
    Khufu's Avatar
    5,693
    now that you mention that...
    Jul 2011
    36
    contact a campany hazzydays they help u
    Jun 2011
    63
    No Sorry i dont have the acutal error code from the guy. They DRL dont bother as long as they dont send a fault error to the computer when i turn the car on.
    I have the DRL switch with 0, I, II and III optiions.
    Mar 2011
    52
    Im pretty sure the 0, I II and III are the headlight levelers. U prob need a new headlight switch as im sure when i say this as i have a 06 plate which came with factory bi-xenon so i had the drl and my headlight control unit had off, auto then side lights, them dipped beam. to the left of that i had drl switch witch is on a roll swith 0 or I and then dial for instrument brightness. Now i have done 8p3 facelift with led xenons, and everything went smoothly. So i think your problem is because you have the halogen style headlamp switch which in 8p2 model didnt have drl unless bi-xenons. so to ramble on.
    Google Images my style
    guessing ur style
    Google Images
    Jun 2011
    63
    Quote Originally Posted by ashaudia3 View Post
    guessing ur style
    Google Images
    You are right i do have the headlight switch quoted above, so all i need is a new switch and everything should work fine?? any ideas where i can get one cheap?
    Mar 2011
    52
    i dont know pal... Im just using logik it still may need coding. If all the equipment u need is there then ur already on a win. Id look on ebay pal. or try audi themselves but i cant see that being cheap
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    A3rider
    Now you know why i asked if you had the right switch ......Send a PM to Nige, NHN (post number 2) he will see you right with a switch and all the details on fitting and coding, if you are anywhere near Kent or SE he will probably be able to get it working as well.
    Mar 2011
    52
    07 AUDI S3 A3 / HEADLIGHTS SWITCH 8P2 941 531 S | eBay it aint local but u get the idea of what u need
  28. #27
    Jun 2011
    63
    Are you headlights like mine? with the DRL on the bottom next to the indicator? Thank you so much.
    A3rider
    Im so Sorry mate, i thought that was for the DRL didnt know there was a new switch. Nah im not
  29. #28
    Mar 2011
    52
    no mate mine is the led 'eyebrow' style
    car picture by ashbenaudi - Photobucket
  30. #29
    Jun 2011
    63
    ahh Alright, mine are the version before. So if i get the switch it should fix my parking light error code.
  31. #30
    Mar 2011
    52
    well i think its certainly a step in right direction. your car switch doesnt have feature of DRL so your car wont know what that feature of headlight is if that makes sense. On mine the parking light is basically the drl on but set dim so one side light in theory. So if youve added the part to your car then makes sense needs the control unit updating. i dont think it will work straight away, ul still need to code it and you may need upgraded modual, like paddy says speak to NHN. Ive seen alot of posts and there full of praise for his help and workmanship.
  32. #31
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    You really need to speak to NHN. It may be poss to wire your DRL's in to the side lights, i doubt your dash loom will have wiring for the DRL switch..also remember there are other versions of that switch depending if you have auto lights etc. I know HNH has done this fix recently.
  33. #32
    Jun 2011
    63
    ALright thank you, all get the switch and change it and see if that helps. Ill keep you posted.
  34. #33
    Jun 2011
    63
    I dont think i have the auto, im not really sure how would i check?
  35. #34
    Mar 2011
    52
    if you have auto lights then your light switch would have auto just like the picture i sent. I think you have lights off then side lights and then dipped beam. if you have auto.. it will be off, auto then side lights then dipped
  36. #35
    Jun 2011
    63
    Yeah your right, when i turn for side lights nothing happens thats why im getting the error code for parking lights then.
  37. #36
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    Quote Originally Posted by a3rider View Post
    no,
    the switch is just that... a control switch for on and off... you have an error which is different!
    i have been running my bi-xenons with DRLs using the old headlight switch that does not have a DRL switch and all that means is that i cannot turn the DRLs off manually... they switch off when the headlights turn on and then the DRLs will turn on again if the headlights are switched off again.
    it sounds as though your DRL isnt wired or coded properly... the light switch is a different issue altogether
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  38. #37
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    oh and also just fitting a new headlight switch wont do it as the car never had DRLs so you would then need to wire in the new DRL position from the light switch to the CE module...
    A3Rider... when you had the facelift headlights fitted did you follow ELSA to wire in the DRLs? unfortunately i dont have ELSA installed on this PC but i can try and check for you tomorrow from my laptop.
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  39. #38
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    this is the light switch you would need by the way...
    no auto position... for facelift cars with halogen lights and DRL switch!
    Google Translate
    edit: this is for LHD models
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  40. #39
    Jun 2011
    63
    Google Translate
    Yeah so you coded it when you turn the car on they turn on and when you turn the low beam they turn of, sounds like a good option. My main priority is getting rid of the parking light error
  41. #40
    Jun 2011
    63
    BUMP
    Can anyone upload a pic where the lights turn on when you put it in the parking position little confused cant find a pic what should light up. Would really help. Is it the DRL or something else had a look old ones had a small bulb next to the main beam new ones dont
  1. face lift
    By ash3435 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2011, 00:15
  2. Pre-Face Lift To Post Headlight Swop ?
    By Dazboss in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2010, 20:43
  3. s3 Face lift
    By lynch in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2010, 21:41
  4. Face lift on A3?
    By steeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2004, 16:47
