Sky InsuranceJMB Retrofits
Results 1 to 38 of 38
    Jul 2010
    53
    H&R springs and shocks or Bilstein B8 shocks with H&R springs
    Right have narrowed my suspention upgrade down to 2 choices. I want to go for a 50mm drop so I can either go for the H&R full kit springs and shocks or I can buy the Bilstein B8 shocks and twin them with the H&R 50mm springs. just wondering if anyone has used either of these set ups. The H&R full kit is the cheaper option so would be keen to hear from anyone who has used their kit.
    pinterovski's Avatar
    Oct 2010
    661
    Add pinterovski on Facebook
    The H&R Kit is a great choice but it can be a liitle harsh ride and the stance of the car is not good (back is higher-huge gap :O )
    but the cornering is just beautifull with that kit!
    Personally i would go Billstein+H&R Route and later some Arb's!
    Black roof,Tinted windows,Solar Orange Calipers,KW V3 Coilovers,
    HEKO Wind Deflectors,CAI ITG Maxogen,Non Res Supersprint Exhaust CB with custom Fi76mm DP,
    RevD with GFB DV+,Autotech HPFP,Custom SKN map Stage2,Forge ShortShifter,THS mounts,
    Twintercooler,Clutch is now on LOBA/SACHS!!!
    18 OZ Ultraleggera!
    365HP and 500NM of torque!
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Consider Eibach Sportline springs for a more comfortable ride. I've just upgraded to these and they are of a similar comfort to OEM Sport springs.
    They are also a progressive design (wider spring spacing at the top and more compact at the bottom) giving better small bump absorption but nice and firm when needed.. i.e. under hard cornering etc.
    They lower 50mm at the front and 40mm at the back to even up the arch gaps, unlike the H&R 50mm. Although I think that H&R now offer a 55mm/40mm spring kits to achieve the same effect.
    What model is your car.... sport/s-line/etc????
    Jul 2010
    53
    Its a sport already running eibach 50mm on the standard dampers and the ride has got shocking. don't know if I can get away with using those springs as they have been on the car about 10 months now thats why I was going to go for new springs and dampers at the same time.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by staitesidestory View Post
    Why do you think you need to change the springs?? It should just be your dampers which are causing the ride problem.
    Jul 2010
    53
    Just assumed that the springs would have bedded in one the standard dampers and that I would need new ones. Is this not the case? What damper are you running?
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Your dampers are probably just shot. Your springs should be fine.
    When you say the ride is now very poor, what do you mean?? Is bouncy??
    I'm running Sport dampers too, so I'm looking at changing them somewhere down the line.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    I would personally go for the h&r full kit as the shocks will be designed around the springs and they will make the perfect combination.
    Jul 2010
    53
    The ride is just very crashy and when you hit bumps and pot holes etc sounds like the suspention is on rocks.
    Quote Originally Posted by Ads (formerly aythree) View Post
    Nov 2006
    7
    your shocks are shot
    why not just go for coilovers?
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    As you've already got Eibach springs, just go for a set of Eibach Pro dampers. They will be perfectly matched to your springs.
    They cost about £450.
    The H&R spring and damper kit is about £520, but I wonder how good they are because that's quite cheap when you consider a good damper kit alone usually costs £450-£500.
    Nov 2006
    7
    excuse me if I'm wrong, but aren't coilovers matching dampers with springs plus damping and height adjustability?
    Weitec are in this price range and I've only read good reviews about them
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Coilovers are matched springs and dampers, but are different to a spring and damper kit.
    The general consensus is that spring/damper kits are more comfortable than coilovers.
    Coilovers will also lower more than springs/dampers and, as you say, are adjustable.
    If you pay £600-£700 for springs/damper kit then you'll be getting something which is pretty good, but pay the same for coilovers and you'll be getting a lower spec/range set.
    If the OP is happy with the height of his current set up then there's not much point in him getting coilovers, he should just replace his shocks with uprated ones. It will work out cheaper and probably more comfortable than starting from scratch with coilovers.
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    my OEM shocks are totally knackered now, gonna get some Bilstein B8s on. Whats the best price people have got, and also which strut diameter do I order, 50 or 55 mm, as its not clear?
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by akash_sky1 View Post
    How many miles did your OEM shocks last??
    Your strut diameter should be 55mm.
    DPM Performance price competitively and will price match if you can find cheaper.
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    As Ads said 55mm fella
    Dark Vader Half sibling - MyThread
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    If you already have the springs then I'd say go for the Bilstein B8 dampers.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by DPM View Post
    Damian, how do you rate Bilstein B8 dampers against Eibach Pro dampers??
    I've got Eibach Sportline springs so I guess the Eibach dampers are the best match??
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    The Bilstein damper is a much better option in my opinion and also the one I'd go for.
    DPM Performance
    T: 01207 561606
    Oct 2010
    661
    There is a thread on this forum specially about Bilstein B8 + H&R combo but i cant find it anymore.
    This is a perfect combo and no coilovers or any other kits will not work like B8+H&R for daily use,track days,...!
    My mate is got them on his S3 2007 and the ride is superb!!!
    18 OZ Ultraleggera!
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    I was just looking around and the Bilstein B12 kit is actually Eibach Sportline (50/40mm) springs with Bilstein B8 dampers??
    Gotta be a good match then.
    akash_sky1's Avatar
    1,209
    Bilstein are the kings of dampers IMO. Many of the best handling road cars use them, including the current GTR. Think ill go for them and get em ordered soon.
    My OEM shocks are on 71k but last 8-9K miles have been using S3 H&R -25 springs which wasn't ideal.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Think I'll do the same in a few K's.
    Your car is a Sport, right??
    akash_sky1's Avatar
    1,209
    Its a Sport with S-Line /Votex kit. So has the sport springs yes.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    H&R S3 -25 are going to give you a drop of about 50mm below sport then??
    akash_sky1's Avatar
    1,209
    Yeah I guess so, hence why my car looks so low even though its riding on uprated springs only, really needs the Bilsteins on..
  28. #27
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Hopefully my stock dampers will last a bit longer than yours then. I'm only dropped 30-35mm at the front and 20-25 at the rear.
    But yeah, when the time comes I'm going for the bilsteins.
  29. #28
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    hi damian what price could you do the b8 Bilstein damper for an s3 2008 facelift ..
  30. #29
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    DPM Performance
    T: 01207 561606
  31. #30
    Oct 2010
    661
    S3kel i would be interesting in group buy
    18 OZ Ultraleggera!
  32. #31
    akash_sky1's Avatar
    1,209
  33. #32
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    We'd need 10 people and we'd be able to offer another 10% off.
    DPM Performance
    T: 01207 561606
  34. #33
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    Hi damian could you do a link to a group buy on these,cheers
  35. #34
    Oct 2010
    661
    Ok,i asked distributor here in Slovenia for Bilstein,
    he give me the price 280eur for rears and 220eur for front shocks = 440GBP!
    If we do a group buy i must pay the shippment costs arround 40GBP so that's 480GBP for me
    18 OZ Ultraleggera!
  36. #35
    akash_sky1's Avatar
    1,209
    Quote Originally Posted by pinterovski View Post
    So shipping would be £40 to YOU from Slovenia, so for us guys would be a lot more no?
  37. #36
    Oct 2010
    661
    akash_sky1, i am slovene :D
    Distributor is in Slovenia,so i dont pay any delivery costs!
    If we would do a group buy i will pay £40 delivery costs,so it's better for me to order bilstein's here!
    18 OZ Ultraleggera!
  38. #37
    Oct 2010
    661
    Anyone got S3 8p pictures with B8 H&R combo???
    I would like to see the stance!
    18 OZ Ultraleggera!
  39. #38
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
  1. Shocks & springs or just shocks?
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th June 2011, 11:29
  2. Springs & Shocks Suspension kits - H&R Eibach Bilstein - anyone fitted?
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd November 2010, 10:05
  3. KW Shocks + Springs kit.
    By djarchive in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th September 2010, 17:18
  4. a3-s3 springs-shocks
    By jeffers999 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2008, 18:52
  5. New springs and shocks
    By rodenal in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2006, 11:57
